Thanks Chris, I was hoping to see some measurements for mid to low efficiency stuff. Like 85dB/2.83V or lower. Maybe some of the 3-4" fullrange speakers. Tho I doubt they will be played very loud, it would still be nice to see how much power they use when playing as loud as they do in normal conditions.
That might give us a rough figure for "Low Efficiency Speakers, How much power do they really need?" I was thinking fullrange, because this is the Fullrange forum, but others are welcome.
When I was developing my current amp I had a pair of Celestion SL6 speakers (the first with a copper dome tweeter) that I used for all my testing, and which had an efficiency of just 82db/watt. I used these for many years on a Pioneer A80 amp (150w rms/8 ohm). The all metal (aerolam) version was the SL600 at more than 2.5 times the cost.
Celestion SL6
Anyhow, the real point is that I wanted to know for sure "how much power I really needed" when designing the new amp. What voltage rails to use and so on. The only way was to scope the speaker drive looking at transients and see for sure. And I was playing this LOUD to really push it and I do remember seeing peaks of 40 volts plus although this was at levels way beyond those I would ever normally listen at. The speaker would have handled more but I decided that -/+48 volt rails was certainly sufficient.
I bought the speakers from a local store (where an ex colleague worked) and I remember us hanging the SL6's the end of a "Doctor Thomas" amp and really cranking it up. What was interesting was that the SL6's despite their low efficiency were also more than adequate for all normal listening on what would be considered quite low powered gear. My parents had the SL6's on the end of an original Rotel RA820 and it was great for normal listening.
Thanks Mooly. I've run low eff speakers that were in the low 80s on 25W SS amps and was clipping. Maybe with a valve amp I would not have noticed it as much. 25-30W seemed to be "enough", but some more headroom would have been nice.
There is no "magic" the power required depends in the speakers. every 3dB difference in speaker sensitivity means your need to double or half the amp's power.
So a 4W amp plying through a 100dB speaker is the same as an 8W amp and a 98db
So I can make a table of systems that _should_ sound alike
5W, 95db
10W, 92dB
20W, 89db
40W, 86db
80W, 83db
Does this seem right be most of you? Would they sound alike?
In theory it should but many people argue that the 5W, 95db system sounds best even if they all have the same loudness. My theory is that either the small amps have better dynamic range or the 95db speakers have lower distortion and sound cleaner. Or likely both.
5W, 95db
10W, 92dB
20W, 89db
40W, 86db
80W, 83db
Yes, that's a nice chart.
Power compression is an important factor and affects the sound. Power compression is very small for high efficiency speakers in a domestic setting. That can sure help dynamics.
It's been discussed a lot in other threads, but is worth mentioning here.
I think it's also easier to make and "overbuilt" 10W amp than an overbuilt 200W amp.
Shouldn't that be 97dB? 97 + 3 = 100.
se
Thanks for the link 🙂
That's good, but the 6dB drop off isn't valid in small to medium size rooms. There is drop off, but not as severe. The 6dB drop at double distance also assumes a point source, I believe.
It varies with frequency. Horns and lines initially fall off much slower, but eventually adhere to the 6 dB rule. Bottom line though is that to ensure enough power handling is to use the rule.
WRT to dynamic headroom, the article's +15 dB isn't near enough for HT's +20 dB and if you listen to some symphonic music CDs, especially the better pipe organ ones you need up to +30 dB and even then the CD's signal is clipped, so can't go 100% 'live' no matter how big/powerful/eff. your system is.
GM
GM
I run a pair of Bowers & Wilkins DM683's which are 90dB/Watt I use a Pass Clone Aleph 4 which is 100W / Channel and the results are absolutely magic.
100W is just TOO LOUD for normal listening but at normal levels everything just works and sounds like magic.
How do you know? Do you drive them to continuous clipping? At what average SPL at the listening position do you find music, etc. most enjoyable? 'Loud' is controlled by whoever has access to the volume control and how much distortion they are comfortable with.
Regardless, as already noted, most of the amp's power is used up properly tracking fast transients which isn't even perceived as 'loud', just more 'air' added around the instruments, so depending on the source material and distance from the speakers, you may be needing more than 100 W just to listen at Dolby's modest spec'd 78 dB/listening position average at low distortion for 'made for TV' movies.
GM
And then there is this other thing: stereo uses two speakers. So, a pair of 82 dB at 1 W at 1 meter would produce ... not 85 dB, but quite a bit more. The reason is that adding two incoincedent sound sources of equal strength adds 3dB SPL, but two coincedent sound sources add up to 6dB extra. Music is a mix of coincident and incoincedent sound over both speakers. Since most of the coincident sound is in the bass area, which requires by far the most part of the power to produce, in real life that pair of 82dB sensitivity might produce a total SPL of 86 or 88 dB when both speakers are fed with one watt.
In order to prevent being caught on an apparent logical inconsistency the following. After all, when you feed one speaker with 1 watt, you need to double this for 3dB extra. How can it be, that if you feed this additional 1 watt into an additional speaker, you could get 6dB more? It is somewhat counterintuitive, but the reason is that with two speakers you double Vas. Feed that into the formula to calculate loudspeaker efficiency, and presto. A doubling of Vas leads to 3 dB additional sensitivity.
vac
vac
A long story ruined by the omission of stating the restricted bandwidth over which your +6dB would hold true.And then there is this other thing: ...........................A doubling of Vas leads to 3 dB additional sensitivity.
If the speakers are 2m apart, what is the bandwidth that +6dB is available?
At what frequency will the stereo SPL gain have fallen to +4dB, or +3dB?
Well, ruined is not the word. The beauty is that in the long wavelengths, the L+R signals usually contain the same coincident signal. That is were your amplification runs out of juice soonest. It is also the bass notes that influence the dB measurements the most, because they contain the most energy. Therefore, the tables linked to in this thread, and which just double power for every 3dB increase, are incorrect, even in an anechoic chamber. These tables do not reflect how sound from two speakers combine in the real world when driven by a music signal.
At higher frequencies you are right in the sense that with speakers some distance apart, you will get an increasing number of lobes with rising frequency. In the central lobe, however, they would still add up to + 6dB with coincident sound sources. That is also the central idea behind the LR xover. Much of the stereo separation is in the frequencies above the low end, so the two speakers shift to becoming incoincident sound sources anyways with rising frequency.
vac
vac
- Full Range
- High efficiency speakers - how much power do they really need?
