Active filter board GB
Here's the board
Hi Bob,
I'm considering Active Filter 4 to be the source for a pair of amplifiers that would power a pair of 10" woofers in a "W" baffle arrangement. Said another way: one line output provides signal for 2 separate amplifiers.
Should I alter either the output of the x-over or the input of the amps for compatibility?
Did anybody make a 3way filter from these modules?
(and did it work?)/How is it supposed to be connected???
Have tried 2 times, both only produced some oscillation :-(
(Have wasted 8 boards (& parts) by now...)
Arne K
I have used them in a 3 way cascaded config. with crossover points of one set of boards at 400hz and the other set of boards at 2.2 k.The hi pass outputs of the 400hz boards fed the inputs of the 2.2k boards.
Jumper JP13 has#1and 2 jumpered together for low pass +hi pass and both JP8 and JP15 with #1 and 2 jumper because I used 4th order slopes. The main input from preamp was into input buffer of the 400hz board,with the low pass output of it feeding the bass amp and the hi pass out feeding the input buffer of the 2.2k board.The low pass output of the 2.2k board feeds the midrange amp while the hi pass of the 2.2k unit feeds the tweeter amp.
Strange, tried the same...(also 4th order). That J13 -option still puzzles me.
Well, have to order a new batch opamps, and try again...
Pic from first build.
Never had any problems building 2-way versions...(built several)
Arne K
