Post your Solid State pics here
yesterday I found this on my doorstep :cheerful:
cant believe I built this some 20years ago
he, nay, it was built fore a teenage nephew
I guess his wife is the kind spender now 😛
thanks Carlos
I think it will need a couple of nicer looking control knobs
hell, I dont even know yet if it still works
not really sure yet what I will do
leave it as is, or change it
I should have the schematic, somewhere
I would like to see the schematics. And one of my amplifiers working afters 20 years, when I were 43 yr' old.
will look fore it ASAP
but I may need ask permisson to publish it
dont know
I suddenly remember the regulated +/-13V supply also have a +12/0 reg out
it is fore the relay/input control switch
makes it real easy to implement a hi-Z instrument input, with a single jfet 🙄
sound of these hybrid, EL84 drive dc coupled to fets, and srpp 6n2p, but video is already blokked on youtube after 2 minutes, but you can see it here.
http://www.youtube.com/watch?v=3FjgtD1x6m0
little child behavior of these people who claim so much, she are already the most rich people on earth, but oke it is kapitalism.
sound truogh youtube is afcourse not so good, and I have no place to post the wav.
legend of instability like most elektor circuits .....
Yes, Sakis, please post those 10+ issues with the crescendo somewhere...
I have seen too many "failed" crescendos. Yes it is a legend of instability. Funny thing is I have never seen one mini-crescendo failed. Crescendo PCB from Elektor imo is horrible, but people keep producing that PCB. Never seen alternative PCB on the net. May be Alex can help 😀 At least for the SSA version as built by Christophe Esperado.
Three_Legend,
that heatsink is way too small. But you can put your amp in front of air conditioner or inside a refrigerator. Indonesians are resourceful, aren't they? 😀
Here is my B1 Buffer with 10dB gain of Pre-amp
ESP P3A clone. Performing flawless for more than 1 year now.
Case is home-made using anodized 3mm aluminum plate and 100x6mm aluminum flat bar.
Heat sinks are HeatSinkUSA 8.46" model, tapped to hold everything together with 8-32 screws.
Reactions: valtra103
Is it a light pipe from a remote LED?
That is it.
I used to use something called 'stretch magic'.
It is a tough elastic available in different diameters, intended for arts and crafts.
Since then I have switched to cheap toslink cable.
Much more efficient and can do any distance.
It does a neat 1mm diameter indicator that fits tightly into a 1mm hole in the faceplate.
It is kept in place on the LED with heat shrink tube.
That is it.
I like it 🙂
Super job on the amp by the way, puts many a commercial jobby to shame.
