No. Sound.
Rugged output is needed for EMI immunity and minimizing cable influences. Most of the reviewer's objections to JC 3 sound apply to sound of the link level unbuffered opamp output stage. It is up to John if he believes or not, he might recall another hesitation he had some 40 years ago. This is similar, just different issue.
Is the opamp output isolated from the load with a series resistor of 50 to 100 Ohms? Hanging a few feet of cable on an op amp without taking this normally recommended precaution often causes problems.
Other possible issue is class B output stage- easily cured though by pre - loading the output.
No. Sound.
Wow, talk about speculation! Like there is not a million other things that could account for a reviewers subjective opinion.
As I recall the JC-3 compared very well against the mega buck competition it was up against and was called an overachiever at it's price point.
Most designers put some resistance at the output of an IC or even discrete output stage to take care of reactance to cables. I don't think there is any merit to your attacks on JC's design.
Sounds like sour grapes to me.
The point is about this phono design is that it is designed as well as a Blowtorch by the same people, but size restraints limited it to using IC's in the gain path from the get-go. If it was possible for me to make a 'perfect' phono preamp from IC's, this should have done it. Everything else was the same level of quality and construction as the JC-1 or the JC-2 in the series.
Since I found that each input IC had its own sonic signature, I am open for suggestions. Perhaps there are better IC's out there that would retrofit and sound even better (that is, if you believe that anything can really sound better than anything else).
How can we suggest better ICs if we don' t know what kind of ICs are used in the JC3?
This is not necessarily so. Usually low noise bipolar input op amps are designed to be loaded with a fairly low impedance, because of the low value resistors necessary to keep the op amp quiet and useful. The second stage fet input usually has reasonably high peak current output. This is because OP AMPS are 'universal' as best as they can be.
Well I just did some power supply tests.
One test was just how much noise was present on the 12v dual coil toroidal transformer with no added noise.
The second was with my noise generator turned on.
The third was the noise filtered by a 4700/50 capacitor with the center tap grounded.
The fourth was using a full bridge and the negative side grounded.
The fifth added a small ceramic bypass to the 4700/50 capacitor.
The sixth had no extra bypass on the filter capacitor but did add bypasses across each of the diodes in the bridge.
Now try to guess which is which before you mouse over the image and have the label give you the answer!
ES
