Class D Amp Photo Gallery
Most of the time its powering some bookshelf speakers (kirksaeter p55) but sometimes i plug other things to it. I did use it to biamp some wharfedales i had before but i really made this amp to try a set up with a mini dsp speakers and that i have yet to make.
My contribution: B&O 125ASX2 in a very small aluminum chassis. Until I get a better name, it shall be known as AMP1
Enjoy!
djank ... english please 😉
maksim, super nice :up: :up: :up: :up: :up:
Is it your own construction or fabricated modules?
Is it a new case or from an older amp. It looks really cool.
Though I think the heat transfer from modules to the heat sinks will not be really efficient, but then again, propably not needed either 😉
Best regards Baldin
I am thinking to make an D class amp... can anyone send me a simple d class apm schematic 150-250w?
This is the reference design for the IR2092 controller chip, if you want to try building from scratch. ljm_ljm here has used it as a basis for his L15D and L20D class D modules, which are so cheap that it hardly makes it worthwhile to design your own. Check out the other threads about them in Class D forum
Thank you for the comments gentlemen 🙂 Davet the vents were cut with laser, the front of the cabinet is made of white acrylic which was also cut with laser for the light hole and the switch button; the light is an add-on. I am finishing a new amp I am building for a friend i'll post the pictures soon. Happy new year DIYers!!
