one your request on a double horn 46" high,
can it be done ? shure but,
the box wil get a lot bigger and heavier.
its going to be less efficient.
heres a picture
left pic uses the same amp load for 4 mcm speakers.
right is 1 box vs 1 box ,the double is 16 ohm vs the quad 8 ohm load
heres a picture
heres a picture
Epa thanks for trying to help me out. I guess for this design to work the box size has to be very large. i was aiming to move more air with few box as possible, i guess it wont work with this driver.
what do you think of 2 push pull lab12 in a tapped horn playing 35hz to 100hz
there is a special topic on lab 12 th i think.
and the keystone sub from weltersys can be used with a lab 12
there are a lot if options out there.
Brian Steele Has anyone done any measurements on a built version of this to see if the response matches the predictions? I'm particularly interested in a comparision between the predicted and actual impedance response curves.[/QUOTE said:Brian I have sometime off next week so i will be doinig some out door testing and measuring.
