JLH 10 Watt class A amplifier
Tim, do you know a retail supplier for the MJ's? They're available from RS and Farnell but they're trade only companies.
Andrew, one factor I've picked up on is the difference in the thermal resistance of the junction to case between transistors. The datasheets quote 1.5 deg C/W for the 2N3055 and 0.7 deg C/W for the MJ15003. From my heatsink calculations that will make a difference of 10 deg C at the junction even with my low voltage version of the amp.
Regards Ned
Hi
Just seen this thread. Built a a pair of these JLH amps for a friend some years
ago. I used Sanken 2SC2922s for the o/p devices as they did not suffer from
beta droop. Dont know if you can still get these.
Other than the o/p devices the rest of the circuit was as JLH designed it and didnt oscillate or do anything funny. Power supply used gyrator like regulators. Sounded very nice at the time.
Hi
Those 2SC2922's look like very nice devices. They are "quicker" devices and the Cob = 250pF, 4 times less than MJ15003. I would have been concerned about oscillation but you say they were fine. I'm sure they will show a much better slew rate than the MJ's on a square wave input. Don't know if one would hear an improvement but it could as the Toshiba I used on the input made a difference with the "attack" of a note. Pianno and strings are just super. So maybe the Sankens can do the same.
There's a lower gain (Beta 55 min) part marked with an "R"
There's a higher gain (Beta 80 min) part marked with an "O"
Lower gain choice might be closer to a drop-in for 2n3055?
I would still plan ahead for reducing the drive current.
Higher gain and less droop isn't going to need so much...
If you adjust bias, then no harm in the higher gain part...
Tim,
Thanks for the link to CPC, tried a search for MJ15003 on the net but CPC didn't come up. There's a price break on 10+ so since I need 8 for four channels, it was cheaper to order 10, which I did this morning.😀
I'll have a few listening sessions before I change the transistors, I just hope my cloth ears can tell the difference.
Ned
my jlh-2005
Repost it here by Johnathan's suggestion...
Just finish my first JLH-2005. The circuit is from this link:
The Class-A Amplifier Site - JLH Class-A Update
schematic and pcb attached.
A few thought about the design
1. The original 1969 design use 2N3055 as Q1 and Q2. Then changed to MJ15003. I'm thinking of some other subsititutes such as 2N3773, MJ21194 or 2SC5200
2. Can I use 2SA1358 as replacement of BD140? it's complementary of 2SC3421.
3. How to set the value of VR1, VR2 and VR3? in other words, what current should those 3 current sources be?
4. Is the large polygon pour on PCB good for audio amplifier?
Tim,
Ned
You should order more than you need and measure the hfe on each. These parts MJ15003 I found had huge variants on hfe. I also ordered 10 of which 2 were not usable at all as the hfe readings were below the specified value. I was quite disappointed with tolerance actually.
I think I'll have to set up a test circuit to verify the dc gains of each of the transistors. The first thing however will be to check the markings on the transisitor case to see if they correspond with the manufacturers data. I've hear that the MJ15003 is one of the most faked transistors.
Assuming everything is ok with the transistors I'll select the best matches for each output stage.
Cheers
Ned
Sil,
I suggest you add a series resistor to each of the current setting Vr1 Vr2.
Try 100r for Vr1 and 10r for Vr2.
This allows you to check and set the target currents for these two stages.
Initially you set the Vr to maximum resistance. This passes minimum current through each stage and that way you don't blow up the amplifier at first power up.
Start with Vr3 set to maximum. This will leave Q5 becoming current starved as you increase IcQ4. The current through R11 must be >>IcQ4/100 and could rise as high as IcQ4/2
it's better to order pair matched parts. hfe doens't mean all. The curves should be matched.
As for power transistors: Beta droop at ~1.5x quiescent
current should be matched. If they don't match at lower
current, its no big deal, the global loop and offset CCS
can handle it. But if droops are wildy different, you are
screwed! At that point you might look to SRJLH if you
still determined to make use of mismatched devices...
The npn driver and pnp error detector are doing completely
different things. Not optimal that they should compliment.
PNP should be optimally sized for gain at only a few mA.
And the NPN driver sized for best gain at around 250mA.
Here's a plot of currents showing some serious droop
The peak current is "supposed" to be 2x the quiescent
but we can see it never gets there!
Illustrating why matching of this flaw is important.
Its not hard to set up a quick test...
