500W PA amplifier with Limiter
I have some problems with my B500, there is high voltage on pin B driver TR. So, i dont dare connecting to final TR.
I try to measure B to B driver TR, there isn't voltage on it.
I try to measure at pin 1 NE5532, when power turn ON the voltage is increase from 0V to 13Vdc slowly. is it true....????
I have a little question, when normal conditions without input signal,
1. how the voltage at pin 1 NE5532?
2. how the voltage at R15 (1k)?
3. how the voltage at R16 (1k)?
Sorry with my bad english...
Thanks before...
You must connect final TR, use 10R instead fuses for test.
Single Pair PCB Finished
Finally I made it, my PCB....
It's time for shopping...
I'm sorry for my first picture attached, they are reversed.
thx
Hand made pcb 🙂
yes it's hand made.
made with DIY tolls too, may someone want to made it like my way?
Perhaps I made it works soon
I want to ask, for testing use 10R/...watt? maybe 5watt or bigger?
Can I change 43k resistor with 47k & 33k with 37k(27k + 10k)?
Thanks you very much Sir
What water-resistan permanent marker you use, and what acid?
For 43k use 33k+10k in series.
I use the big permanent marker, draw with 2 layer for best result.🙂
My modified pencil tool is very helping
The acid is water + FeCl3(ferryclorida from e-shop at Denpasar city)
btw I'm just a villager but not so far from the main City (55km)
Now waiting for few more component that my bro will buy tomorrow, we must be patient for best result are we?😀
Okay I will use 33k+10k
