Power amp under development
engel dela pena: When I draw my PCB for NMOS, I do not have read about Baxandall correction – now I use this diode in other my project (UNI_50_Q)…
D1,2 and ZD2,3 are protection diodes for MOSFETs
Hi Sandeep, You should not run this amp on such low voltage rails. If you must then R7 needs to be replaced with a lower value resistor, try 4.7k. This will ensure the first stage constant current source works properly.
Remember to restore the original value if you choose higher rails >60v.
Quasi
Hi greetings QUASI
what happened with NMOS MKII under development ?
Do you have finished final design with symmetrical clipping included cascoded second stage ?
I have build NMOS MKII under development and it works fine,... but have replace string of 3 1n4148 with 1 Amber LED
regards
Hello have a problem with NMOS300/500
- amplifier has a little quiet noise without Input signal from tweeters
- and if I do connect Input to ground the same quiet noise comes out from tweeters
I can hear it 4 meters far away from spaekers
does somebody have similar experience or a solution ?
attachment schematic
