bass speaker help
thank you
Right now I'm stuck at the curves
well, I'm very excited whether it will give me the decired monster tone
but need to do them curves
some veneer would be nice
maybe I should try a get hold of some
hey, managed to cut a hole for the 15" woofer
looks kind of small 😀
ok, small problem, but solved
its the foam I plan to use
the spraycan can't be used more than once
well, there are other types of foam, but whatever
I found this massonite back panel from an old wardrobe
slicing the plate with a hobby knife makes it more flexible
not much work really
then I can just fill up with foam, after its glued into place
that should work ok
that last curve baffle proved more difficult than expected
but it done now
just a reminder, there's a horn mouth on both sides
'the voice test' sounded nice and soft
can't wait to play some nice bass tunes through it
maybe it works, maybe it doesn't
but its exciting 🙂
now on to finishing
and maybe some wheels 😀
Here is a website that should be checked out by anyone wanting to build their own bass cab. The fEarful project is fairly recent and is the subject of many threads over on the talkbass forum. There are lots of contributions from builders with pics and tips and reviews etc. I myself am planning on building two of the 15/6 tube cabs this summer when the weather improves.
fEARful enclosures for bass/drums/keys
Here's the designers web site. He has in essence contributed the designs to the bass playing DIY community.
Apologies to all if someone else has already pointed this out.
There is now a dedicated fEARful forum as well, and kits with all the panels pre-cut and all the crossover parts and boards included.
