100W Ultimate Fidelity Amplifier
im a bit confused, because if you look at the parts layout on pcb, the diode is placed before the .33 ohm resistor. thats why im thinking if i will be putting another diode to another output pair. by the way what is the job of the 2 1n4007 diode there?
can you post some pics of your ax-14 project with 2 or more outputs.
thanks
Maybe for rectifier from output power amplifier for adding a voltage to rail..
To
Mile
Sir bought new transistorsToshiba 2sc5200,2sa1943 and 2sa1837
i am in a way to buy other components to diy ax-14.
http://img708.imageshack.us/img708/4732/sam0033m.jpg
http://img651.imageshack.us/img651/1996/sam0034d.jpg
Tell me whether these are genuine or not.
And also i need a pre-amp that having 2 mic(0.60mV) and 2 aux inputs(150mV) with tone control for AX-14
can i use piezo tweeter along with 100w speaker at 8R?
thank you
I think image in http://img708.imageshack.us/img708/4732/sam0033m.jpg is genuine
Hi Mile
I have build this amplifier the problem is the dc output is nearly 5V when 100R are placed instead of fuses and another thing is positive rail 100R is getting hot while the other one is no heat what could be the problem? please help me.
