Dear Fran,
Try Breitbandlautsprecher und mehr - SpectrumAudio 70.00 Euros each, Wolfgang there is a very helpful guy.
Jim
Jim
Germany's Blue Planet Acoustic is another official Mark Audio dealer
http://oaudio.de/Lautsprecher-Chassis/Markaudio
I got my Alpair 6Ps from them with good service.
Thanks so much everyone!
Next question: the difference between the gold and grey is cosmetic right?
Some say it depends on your music.
if your hard-core into HipHop, stick with the gold
Cosmetic yes (except the black CHR called BB04). They may be called gold but they are actually copper. Gold CHR70 are actually champagne. The last gold drivers were the original A5/6/10.
dave
dave
Dave, the BB4.AL expected to have slightly more bass and smoother treble vs regular CHR?
-Zia
my build update only just gone back to these
just need to round all the edges bit more sanding then apply a finish , should be ready by the end of week
Center channel speaker for Mk3 surrounds?
Thanks to the great minds on this forum, I've built four of these lovely puppies. Recently I tried them in a 5.1 system using one of my Tekton FE126E bookshelf speakers as the center. To say I was blown away by Dana Krall's "Live In Rio" Blu-ray is a total understatement.
If I had the space I'd build another FH Mk3 for the center but I'm very limited here as the TV is in a Queen Anne bedroom cabinet.
My space constraints for an enclosure are no taller than 7 inches, no deeper than 7 inches, and no longer than 30 inches. Should I consider a bass reflex design and could the FE126En be mounted in the center of the enclosure?
Any help or recommendations would be appreciated by this newby to DIY.
Optimal BR for FE126En is about 4 litre and reachs to about 110Hz. I will be drawing this plan and releasing it sometime.
Keeping to 126 is best to retain similar voicing.
The size you have is pretty close to that of a microTower. Scott, is an ML-TL of some sort with Zd of 50% possible?
dave
dave
As Dave has pointed out you certainly can build a speaker for the center channel. As I understand it, the center speaker is confined pretty much the vocal range to lock onto the dialog shown on screen, so the frequency response doesn't need to go any lower than 100-200 Hz to serve as intended. The use of the same driver will eliminate any discontinuities in the sound and should sound very good.
Best Regards,
TerryO
Best Regards,
TerryO
Best Regards,
TerryO
And providing the Surround decoding (receiver/HTPC/processsor etc) has modern levels of calibration / XO filter settings, you can generally achieve a close to seamless tonal balance across the front row.
As mediocre as it sounds for music alone, I never ceased to be amazed at the sophistication of EQ and calibration built in to my $400 Denon AVR1610 receiver - plug in the mike and punch the Auto-Set up on Audyssey, go grab an adult beverage of your choice ( mountain plantation green tea is nice and relaxing) and you're done.
I'm using a Blu-ray with 5.1 analog outputs to decode DTS-HD for my non HDMI Panasonic XR55 digital receiver. The music videos are just stunning through these wonder horns.
I'm not missing out on two channel sound with the Mk3's as I'm using a Niles amp switcher on the rears and listen to them via a modded PlayStation and MiniWatt ( fits nicely under a night stand and the boss lady hardly knows they're there ).
She might have objected to four Frugal Horns in the bedroom had they not replaced larger stand mounted speakers. She still thinks watching HDTV requires a surround system.
Dave, might you be releasing your center speaker plans by fall?
You mean the little 4 litre? Not specifically a centre, just an excercise to show that if you want bass the FE126e needs a horn (or a woofer). I can make these happen before fall.
dave
dave
Would the milli work close enough for the surround processing / bass management to take over?
I won't need bass from the center speaker which primarily handles vocals. The FH + sub gives me all I need.
I've got my center ( Alpair7) XO'd at 120 and mains at 110 - works like a charm - so provided you can get close to that from the FE126E in a small enough enclosure to "fit the decor", you should probably be fine.
- Full Range
- Frugel-Horn Mk3 Builds & Build Questions
