jFET Power Buffer
Yeah, but Crystalonics only has them in TO-39 metal cans. What I find most appealing about the KP903A is that it's a stud mount.
se
Yes, TO-39 less convenient, but can also be adopted by specially designed heat sink. Surface area of even TO-39 case is enouth for dissipating 5W via thermal grease. By the way, there are also russian version of these jFETs in TO-39 case, they are noted as KP601A.
Yeah, but just drilling and tapping a hole is much simpler and elegant. 😀
Since I only need to dissipate about 2 watts, I could probably just get away with using a pair of CP650's and some clip on heatsinks.
se
Vladimir
are those КП903А or КП903Б , and what's differences between these two types ?
Yes, the types are indicated correctly, the 903A is the best type , the 903Б has lower transconductance and higher noise, the 903B even more higher noise.
I enclose datasheet in russian, for the case if you manage to read it somehow.
I just have measured output power of this jFET buffer (with preamp connected, 20dB voltage amplification). With 7,2 Ohms resistive load it gave 4W undistorted 1kHz sine signal at the output.
Enclosed is also the sine signal at clipping condition, 1kHz frequency. There are no sharp edges.
Here is the picture for 100kHz square wave, preamp at 20dB amplification, near clipping, 7,2 Ohms resistive load.
Signal generator is not perfect, gives small spike at the front edge.
I'm sure a lot of people would be interested to try these jfets out. A group buy organized by someone in Russia/Ukraine would be nice. I'd definitely like to have a look at these devices. Thanks for showing us your circuit, Vladimir. I'm trying to get some from Russia right now... but don't know if it'll work.
Idss is usually around 700mA, pinch-off Vgs voltages are -5...7V, transconductance near 100mS. Matching, as usual, not very good.
In Russia, these jFETs are not popular, most DIYers prefer to use C5200-A1943 or MJL.
In USA they are quite available (CP650, CP651), simply one must pay 10 times more. But, I could suppose, US parts have better silicon purity and technological norms.
Are you able to, and have you run a curve trace on these to see how linear they look?
_-_-bear
Ok, I just found the data sheet for the CP650 device, a "new" in 1976 power jfet.
The RDS on is ~5ohms.
The max vds is ~20v
The CP650 are apparently somewhat available in the USA at not so high a price... fwiw.
However these are in "T0-5" metal cans... although they rate them at 8 watts, it's unlikely that they will handle that much power for very long in that case.
Wonder if we can have a better look at the KP903's case? Maybe with something along side to see the size?
Thanks...
_-_-bear
Yeah? From whom?
Yeah, well the 8 watts is for a Tc of 25C.
Here's a datasheet Vladimir was kind enough to send me the other day.
se
ummm... Mouser according to a link on the datasheet page I found, with the Mouser pricing... fwiw.
Sure that wasn't from back when the Mouser catalog was barely half an inch thick?
I just checked Mouser's website and the only thing "cp650" brings up is a set of pens.
And the only active producer of them according to PartMiner is Crystalonics. Crystalonics wants $17.25 a pop for 'em in 1-99 quantities and $15.25 for 100 pieces and up.
PM me if you want to maybe split an order - BUT the power handling has to be far less than the Ruskie part due to the case and pins... imo.
Yeah, I'm aware of that. Would really like to get the Russian part. But if the US part can be found somewhere for a reasonable price, then paralleling a couple would be a viable option.
se
