Annoying remote control issue
@FarmTech, Danzup
I'm using FarmTech's firmware version with the group-buy project from the first page (post #5).
I have a small but annoying problem with the universal remote control I just bought: Philips SRU1010 . Being a universal control I set the first Philips TV code for it then managed to learn the volume controller its IR commands.
Everything works but when I push once the Vol +/- it jumps two-three even four steps and rarely only one. I tried several other TV codes and re-learn the volume controller but without success. With another rc it works fine but I would like to have this simple one for it.
Any suggestions what should I try? I'm a programmer so if the source code is available I might find a solution for this issue.
Thanks, Zsolt
@FarmTech, Danzup
Thanks, Zsolt
Hi Zsolt,
I think its the Remote thats send code to fast
What I can try do for you is add a small wait for VOL+ VOL- in the code
Is the version of DanZup software (FarmTech) with LCD and NO VU ?
addon zip
addon zip
Strange that the source selection works fine, one click one source. Only volume commands act strange.Hi Zsolt,
addon zip
Thanks for your quick reply/help! The version with LCD and NO VU is good. I had in plans to add VU as well, but that might never happen.
Hi FarmTech,HI Zsolt,
let me know if this fixed your problem !
added wait x 4 for volume steps
Your mod fixed the problem. Thanks!
hello,danzup
Forumul electronistilor • Vezi subiect - Controler selectie surse / volume atenuator
Attachment can not download, I would like to experiment with each program are
hello,danzup
If you want to download, you must register first.
You have to open two windows - one in Romanian and other translated. When you register, you can download and, in the same time, you read text in English in other window.
You can't register in translator.
I have registered and active, but still can not download, always prompt attachment does not exist
You are right, files are deleted.
Maybe I can help you. I have some files in my computer. You PM me and tell me which files you need, and I can send you what I have on your e-mail.
Thank you,Already PM🙂
E-mail has been received, thank you again
Always most interested in this program,5 button control, so DIY it a lot easier,
Unfortunately, there is no firmware
Sorry for the late post !
Here the firmware .
Halo Farmtech,
Your firmware R2r LCd no VU, can you recompile for Mega8535 (Dip) (If it can fit for M8535)?
Halo Farmtech,
It cannot fit in M8535 as the Atmega16 firmware variant of Farmtech occupied circa 15,9K of flash (99% of flash).
He and me must go to atmega32 for further facilities to be add in future .
- Analog Line Level
- Yet another Volume controlers and source selections
