Salas hotrodded blue DCB1 build
Can I just check, I have a new Transformer I want to use for convenience (has other useful voltages for my pre-amp remote volume and led volume resistors. It's 2x15VAC but on UK system runs to 18.3VAC.
With 18.3VAC hotrodded DCB1 running at 9.14 DC, how big should my MOSFET sinks be? Will normal small cast sinks do the job? Like these I have on at the moment:
AAVID THERMALLOY|ML524-30-B|HEAT SINK BIG CHIEF TO247/218 | Farnell United Kingdom
Many thanks
Lucas
Hi Salas,
Well, it's those standard Hotrod 5W 10R Dale resistors. Is that what you mean, or do you want me to take a measurement from somewhere?
I'm guessing it will be fairly hot with 18vAC transformer, right.
My last one worked great - it was 14vAC, but this new 18vAC one has some other useful secondaries for this amp, and is R-core so low EMI (It's a small box).
Lucas
They could hold in England not in Greece. But enclosed, I doubt you would have 30C ambient. It accumulates from radiated. If it hits 55C+ on sink in the end is unhealthy even if those MOSFETS are TO-247 proven dogs, which they are.
