How is it possible to change between the filters ?
I use Silk Volumen trafos and no analog filtering at all.
If you are using OPUS in hardware mode, you can read p.42 of the data sheet (http://www.wolfsonmicro.com/documents/uploads/data_sheets/en/WM8741.pdf) and adjust the FSEL switch.
Decided to buy an Opus...
After thad decided to not buy an Opus...
Three weeks ago I suddenly changed my mind and
decided to Buy an Opus.
Then lightning struck and I needed new glasses so I decided
again to not buy an Opus.
But since I'm only human I decided to buy an Opus after all...
And now it is out of stock. Just my bad luck...
Any idea when it wil be back in stock again? Before I change my mind again?
![Stick out tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thank you very much I will do that sometime . Now I am working on the Buffalo II dac. I like that it is on only one PCB and not al lot like the OPUS .
I think they are to busy with their families .
I think they are to busy with their families .![]()
Ha! I only see my family these days when looking up from piles of parts/labels/bags
Opus is actually in stock at the moment, but the LCDPS is out of stock for a couple weeks, so the combos are out of stock.
1- I'm planning to use the Opus balanced. Do I need an additional outputboard for best results?
You shouldn't.
2- will you guys help me with switch positions?
Of course. Probably better to post those questions on our support forum, however.
Time to hire some summer interns to clear your backlog
If seeing your family results in my Legato/Placid delivery getting delayed -- you are more than welcome to introduce that delay.
Hesitated some more and finally jumped. My Opus is waiting for a plane in New York at the moment!
Hey all,
Managed to hook up my LCDPS + OPUS DAC 2.1 board to a jkeny hiface USB I2S module last night. Sounding great from 44khz to 96khz files. Doesn't seem to work with 174khz or 192khz files. Just get a constant 'FM radio static' like noise. I noticed this when I try the Test bell playback sound under windows 7 -> control panel -> sounds -> playback devices -> supported formats. 44/48/88/96 would play perfectly, but 174/192 would just give off that static noise and stay like that until I play something between 44-96khz. Have asked jkeny for any advice and his reply:
- the Hiface uses MCLK of
- 128*fs for 176.4 & 192KHz;
- 256*fs for 88.2 & 96KHz;
- 512*fs for 48 & 44.1KHz.
You might check that this is the MCLK speeds that the WM8741 expects?
I'm not technical enough to understand if there is a compatibility issue or I have not configured the settings of the dac properly? I did show jkeny the photos below and he did say they seem to be wired up correctly.
Is anyone able to shed any light as to why or what may be causing me not to be able to playback the 174/192 signals? As far as I know, the WM8741 chip supports 24/192 and the jkeny hiface usb i2s (based on hiface evo) supports 24/192 output too..
thanks in advance![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Tuyen
thanks in advance
Tuyen
Hi HAL2010,
I just did some intense googling and found what each dip switch does and I did notice that OSR one you mention.
As my DAC was on default recommended settings as in OPUS manual, it was set on the middle point (88/96). If I switch it to 1 (176/192) will it affect the quality of playback (in theory) of 44 and 88/96 files ?
Thanks for your prompt reply.
Muchly appreciated.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Tuyen
Muchly appreciated.
Tuyen
Hi HAL2010,
Muchly appreciated.
Tuyen
I use the switch to select the native sample rate of the file played.
You will have to decide if the difference in sound quality is audible in your setup.
Hi HAL2010,
Muchly appreciated.
Tuyen
What is happening is that you turn off the internal oversampling when setting the switch to high sample rate, use 2x oversampling with the middle setting and 4x oversampling with the lowest setting.
H I F I D U I N O: OSR bits in WM8741
In addition you influence the internal filter performance. In my experience it is definitely best to match the OSR setting to the source frequency. To simplify this, I usually up/down sample everything to 96kHz in the player OS, which is clearly less destructive than playing with OSR set wrong on the 8741.
YMMV, of course...
Frank
I use a modified version of glt's HiFiDuino code on an Freeduino uC to control the Opus via the I2C bus for both the OSR and FSEL settings for each file I play back. It is easy with an IR remote control to do this for every song if needed.
Elegant implementation! I have front panel switches for OSR and FSEL, but run a blend of Opus and Buffalo DACs.
- More Vendors...
- Twisted Pear
- Mr White's "Opus", designing a simple balanced DAC
