500W PA amplifier with Limiter
hi apex sir.
today i checked the amp with regulated power supply. i set to 75v dc. but no worth, same heat then i off the power.
so i set to 55v dc then in the power supply resistor 2.2k 1w getting very hot. so what is the solution?
If you don't want heating resistors use separate +/-15V DC PSU without 2k2/2W resistors and 15V zeners for suply NE5532 and unregulated +/-83V DC PSU for suply amp.
hi apex sir,
today i prepared the second channel of the amp.
i put two pair with 55v dc supply with 10a fuses.
after power on one of the part is burn, the smoke is gone like a rocket.
but i cant see the burn part. but the parts are very clean.
there is no darken marks in the board.
here are the photos.
hi apex sir,
10uF/100V is burn, and you have fake 2SC5200.
