500W PA amplifier with Limiter
today i changed the resistors to 5w 3.3k. but with 53vdc it is normal hot. for the 80vdc its getting very hot. i cant understand why is this getting hot.
i checked the volatges across the zeners it shows 15.2,15.1vdc.
22ohm resistor across shows .65v.
dc offset is .90v.
i am getting very angry for this problem.
dc offset is .90v.
There is no problem, disipation is normal P=U2/R, with increase voltageX2 you have increase power(disiparion)X4.
Voltage on resistor is 80V-15V (on zener)=65V, P=(65X65)/3300 = 1,28W and resistor getting hot.
can you give me the foil pattern of the xlr input circuit?
thanks,
joel
please reduce the image until it fits with the parts size.
5W wire-wound sandblock resistors can withstand temperatures over 100°C. Let's say the 'normal' working temperature would be around 70-80°C . What does hot mean? Your body temperature is around 36°C which means, a 5W resistor under normal working condition should be hot. Little philosophy here. If you have a lab thermometer simply attach the probe and do a measurement 😉 If you don't have one, I recommend you to buy one. It's simply a must and for every electronic hobbyist.
Digital Scientific Thermometer 2 K-Type Sensors DT804A | eBay
