Photo Gallery
Agree, slim amps are .... slim!:)
I am just in the process of remaking my Stealth, adding a second line input and an iPod docking connector. The chassis is the Hammond 2" standard steel box. Painted everything black (transformer bell ends) to make it more "stealthish".
I haven't started yet but have parts for a Luxman clone with 50CA10 and really want to make it really really slim, preferrable around 1". I have opportunities to work with sheet metal at my work.
I was looking around for solid matallic (aluminium) knobs but found only "hybrids" (plastic/alu). Then accidently I made a purchase from AES and looked at the knobs at the AES website and found exactly what I was looking for.They are names P-K311 and P-K313.
In a preamp I am slowly building I have installed LEDS in the recesses behind the knobs. Looks rather nice when it's dark.
Top plate and sides are copper.
Nice, I like slim amps. Best antidote against boutique caps. This guy has the world record for a tube amp.
yeah that was my idea to make it slim as possible.
The amp you posted...Ooohw yes thats so sexy !
Wow thats pretty unique design ! love it !
Tubemaniac: What are you using for a power switch/button? Is it stainless & illuminated?
Buttons are vandalism proof ones. Still cheap ones but they are nice !
I like the vandelism proof switches, they are available in different sizes and ilumination colours.
Compactron Triple Triode for input stage and LTP, Compactron Sweep Tubes hooked up as triodes, so a Complete Compact Compactron Triod Amp...... with a nixie tube displaying the tube selected for the amp meter..... select 1-4, 0 or nothing also. I was lazy and did not want to have to engrave or put a decal on for the switch position , thought it might look tacky..
EL34 single ended parallel ultra linear
EL34 single ended parallel ultra linear 15 Watts per channel < .1 % THD at 15 Watts 1 KHz. Built from scratch at my shop. The ghoul here was to build an all tube amplifier with as good of specs as possible, using modern components but keeping to a traditional design scheme. I spent 9 months designing and building this amplifier and it was worth every bit of the time spent. This amplifier running a pair of the small Advent speakers sounds incredible. The dynamic range is like nothing else I have ever hired. But then I built the amp... so not trying to be partial. This amplifier will not win any beauty contests, but it sure is perty to me. Bernie
Can you post a finished and final schematic. I have a quad match of Mullard EL34s new issue. This amp could be the one to build.
