TPA3122 doesn't work
C3 and C4 are plastic capacitors, I don't know if they are low-esr or other special capacitors.
That there may be part of your problem. C1-C5 should all be monolithic ceramic caps. Inductively wound caps (rolled foil) can cause many problems in high speed switching circuits. There's a reason you see all those little chip ceramic caps next to IC's on modern digital PCBs instead of standard film types.
Tried switching them to ceramics, didn't work. :(
I've built quite a few different PCB iterations using this IC and they have all worked (and I'm no professional by any means). Some had hum from bad grounding, but they did work.
Would it be possible to get the layouts and masks (just as a gif file), I would like to try out some of them?
I really don't think my layout will be of much use. It uses 1uF 100V X7R ceramics for every cap except the main power caps and 100nF decoupling caps.
The board is double sided and all the ground pins are soldered to the top side ground plane.
  • tpa3122d2n.pdf
Thanks, but a plain gif file would be more useful (I would need to make a negative mask) if it's not too much trouble. :)
Anyways, what do you mean with it not being of much use?
Sorry, the program I use doesn't have an option to output/save as a GIF. I'm sure you can take the PDF I posted and convert it somehow. I don't have time to figure it out right now though.
Well, I just meant unless you have the exact parts I used you will have to do a lot of improvising.
OK, I don't know if this is what you were looking for, but I gave it a shot anyway.....
I have SMD components around, so I can probably figure out something. If you can send a picture of layout (with component values), that would be nice too.
I don't know when or even if I would be able to do that. I don't even make those notes or diagrams for myself as I find it tedious. I just rely on memory. :eek:
I think the best I can do for you is show you pics of a different version of the board I made and let you try to reverse engineer it a bit. It's a simple enough circuit.
http://www.diyaudio.com/forums/class-d/124318-my-tpa3122d2n-btl-proto-6.html#post1872915
I will mention there are three "vias" that are just wires soldered from the ground plane to pads on the bottom. One is near the gain jumpers and the other two are on the ends of the output filter caps.
Sorry, that's the best I can to right now.
Also, here's the new PCB I made (+ masks), this one is SMD. (the mask has four of them because I made a stereo one, and masks printed with a laser printer work better if you use two of them on top of each other)
Now it works otherwise fine, but it still has one problem: you hear a high-frequency whine from the speakers, which I suspect is the difference between the switching frequencies of the two amps. I tried to regulate the voltage supply to the preamp, but this didn't help. Also, this whine isn't heard when the inputs aren't connected, so I suspect it's because of the preamp.
i have the same problem,too
