500W PA amplifier with Limiter
Op Amps
Hi Jon2xflash,
4558 can be used instead of 5532 as I'm also using the 4558 on my B500 amps.
Attached herewith is the B500 amp circuit without limiter.
Blueice23
Hello Apex !
I have read most of this thread today and saw some changes made. And I was wondering if you could make a complete pdf with all the new components, PSU, Bridge board, PCB's... I think that would help many other so they don't need to search the 137 pages for the latest version.
So I want to make this amp could you recommend the best Input voltage ?
Thank You Very Much.
Hello,
I have assembled most of the parts for B-500. Transistors yet to be soldered.
I will be using Regulated Psu giving 75-0-75 dc, and 4-10,000 mfd capacitors, Do i need to make any changes.
Currently i am having 37-0-37 5 amps transformer, Can i use this to test the amp.
The heat sink is 15" long height 105mm and fins length 44mm, I suppose this should be enough.
Will kse350 work in place of mje350.
I am assembling a amp for first time without any help, So tell me how to set bias for the transistors. And what initial steps to take for testing the amp.
I am not getting relay for protect, can i get any photo of the sample or link where to buy it in India, is it fine if i connect the speakers without protect.
hoping for the big miracle.
Thank You🙂🙂
