The Very Best Amplifier I Have Ever Heard!!!!
The "DC-problems" and my wish to solve it might be a try to "shoot sparrows with cannons".
By the way I have not tried to use BC 546 B for T3/4. I think that will be my last attempt and and then accept the DC level I have. It is by no way dangerouse for my loadspeakers (left better than right).
Eivind Stillingen
Nico
My first measurement showed a unstable DC level that changed from 0 to 80 mV. I tried to match T3/4(MPSA 42). No results.
After using MJLs power to the front end, one channel have 0-10 mV. Very good. The other channel is still unstable. But as I said in my last post, it is nothing dangerous, and I will not loose my night sleep because of this.
By the way, our Danish member, Tommy, sent me this: http://www.diyaudio.com/forums/solid...uipment-7.html
Read post 66.
I have tried it. There was no light in the LED, but how mutch can one rely on a simpel circuit as this one??
Eivind Stillingen
Correction
It was Karsten Søman from Denmark who brought the "oscillation detector", not Tommy. Sorry, Karsten.
AutoClassA
If you at any price wish to go for SK/SJ, it is "sellers marked" = exspensiv.
I use Exicon , and I am very pleased. Its more than half the price.
Eivind Stillingen
.....🙂 my drivers are 2SC3423 and 2SA1360 with heatsink .
Alex.
Bigpanda
Drivers: I use MJE 340/350 (300 V) mostly because they were easy to get.
Alex: The devices you use for drivers are 150V transes. Have you read
"warnings" in #1318 and1321 about not use less than 180-200V types.
(This also depends on your power voltage).
Your PCB seems to be complited. Have you listen or done any measuring?
I am curious about others exsperience with the clone.
Eivind Stillingen
