Konzert Amp & Speakers Website
sir you could check the Vgs drive. if it reaches |10 to 15|volts, then it is safe to use standard mosfets. but if it is just in the vicinity of 5volts, then the use of logic level mosfets is a must. (i assume you are trying to substitute it with other part number)
yes sir, actually the MOSFET was a rail switch for a 6 Kw power amplifier with all the power transistors blown (20 pieces per channel all blown, all channels blown) I am assuming that the MTP60N10 has too much gate capacitance (too slow) causing a bit of a latch up on the output rail and to add, up there were 2 mosfet (in parallel) per rail step, hence doubling the gate capacitance.😱
boss.. what is the size of that horn?? how much? salamat
what brand is that amp sir? 6kW!!!! wow.
