I need 2 x transfomers for my Dual Mono F5 with 70W/8 ohm - 140W/4 ohm.
I have gotten several offers from a company, I can either get 2 x 800VA standard transformers OR 2 x 500VA Audio grade transformers, for the same price.
Audio grade gets you this :
In audio grade, noiseless transformer price You'll get transformer wound on high inductive, selected and measured core. Core and all the windings will be impregnated. Transformer will also has electric and electromagnetic shields, epoxy filled interior and mounting pads in price.
Is it worth it? Lower noise is always a big plus...
Hi regireg122
Well in my case yes the of the top of my wooden head they are 2.2K used to slowly bleed power off when the amp is switched off.
But not sure if this is relevant in regard to the topic we were discussing.
Neutrality was proposing to interrupt the supply to the amps in case of a fault (Mosfets short circuit) the bleeders are somewhere else in the circuit.
Just to recap from what we were on about.
IMO big IMO
To place fuses or relays in series with the speakers is certainly an option in my case I could not cope with Her telling me I told you so if I blow the Polk (besides customer services is not the best there is as far as I can tell for now at least here in the UK)
The fuses have timing issues the relays which must be rated for DC current (DC ark between the contacts and is much worst than AC in this regards just see the rating for the relays not many give you the contact breaking capacity for DC) and they are either expensive or really cheap the contacts are made with what not and can be sonically worst than a fuse.
There is a much better written explanation of this in Bob Cordell book, which was also quoted here, word by word in another post under different credentials...
So with Neutrality we were discussing the option of fuses in Neutrality view to disconnect the supply to the Amp modules.
This sound to me like a better option as it should not effect the sound too much.
At this stage and I think we should give this it time to circulate
Neutrality view is to place fuses on the output of the capacitor banks.
F5 is a fairly constant load on the supply and this is certainly an option
My question was (and I need help with this please) was to use a mosfets as a switch
Question: what is the heat load that this solution would present the mosfets would be in the saturation region so the resistance seen in the circuit is very small would the power dissipated be small also?
I got plenty of spares that did not make it trough the matching so it would be cheaper than a fuse and ancillary and it could sit on a corner of the heat sinks
I had another question relating to the control circuit for the switching mosfets
My thoughts where as the musical signal is made up with waves the voltage at the speakers AC in nature will cross the zero line say for a 10Hz sine wave every 25 milly seconds (is my math correct 1000/(10 X4) )
So I was thinking to use a LM339 to detect the signal voltage rising edge and set a timer a second comparator to detect the falling edge and reset the timer before it reaches the time out of say 50 mS the comparators with inverted functions can perform the reverse on the negative branch of the supply
If the timer’s time outs they latch remove the supply to the gates the mosfets stop conducting speakers safe
It will also work as DC offset protection maybe as the 339 set point can be set to work allowing a tolerable DC offset
So I am big enough now to play with a 555 (maybe) but I don’t think it will be good enough so any one to help with this please.
Tanks
IMO big IMO
Tanks
detect the zero crossings.
Send a pulse for each zero crossing.
Use a 555 as a missing pulse detector.
Trigger protection on missing pulse.
However, I would use some kind of "and" to detect the average signal after rectifying. If the average of the rectified signal is >threshold AND missing pulse detector is active then activate protect.
Some music signal is not symmetrical, I suspect this asymmetrical signal could trigger on no zero crossing too often to be tolerated and eventually the user turns off the protection.
Whereas with a zero crossing/missing pulse AND and excessive average DC (either +ve or -ve) the threshold and/or the duration could both be adjusted at build stage to eliminate most, if not all, of the nuisance triggering.
So, any opinions about what to choose?
I would probably choose the 2 x 500va 'audio grade' but only to have 2 PSU pcb, and make it dual-mono.
With 2 PSU PCB (such as Peter Daniel's) you would be able to tune the amount of capacitance easily.
The shield and epoxy may have a nice benefit as well. 🙂
Well, my plan was already going dual mono and I have made my own PSU PCB design. Just need to get it manufactured.
Getting a pair of "audio grade" transformers does seem tempting, but a transformer can never be too big so getting the big 800VA has its merits as well. 60% more current capability is nothing to sneeze at. 😀
Maybe I should just pay the extra money and get 2 x 800VA "audio grade" transformers. Sometimes its better to buy the size you want from the beginning. On the other hand, for a 70W/140W in 8/4 Ohm amplifier 500VA pr channel should be more than adequate.
Decisions, decisions, decisions.
well, yeah a rather smallish kids bass 😀
man, this heatsink is so heavy I can barely lift it 😱
bought in a moment of insanity
oh, and my supply caps arrived today, yeah
wrote to Mr Schuro in Germany about trafos, but no reply
Easy to cut with circular wood saw.
Toroidy?
Toroidy?
Only joking realy made up for you
If you don't mind How much?
Going to get them anodised?
If you do make shure you got a hole or fit a bolt where you are shure it will not be seen as they need an electrical contact
Me plonker toke them to the shop in a rush and now they are scrathed just in the wrong place
It looks like you spent some serious money there.
It is good to see people taking ther hobby seriously 😀
are those capacitors from the european supplier you told me? I wrote them for a quote but got no reply.well, yeah a rather smallish kids bass 😀
yes, they are
I think you have to order industrial package to get better prices, or other types than listed
35x95 has case code D, which is "only" 45 pieces
but prices are quite fair as is, so probably wont get much better
and as a bonus, they come with all fittings, like nice brass screws etc
4700uf/63V aint much, but the can size 35x95 fits my planned design perfectly
in 40V range it could have been 10000uf, but no stock
8x 4700uf per mono will have to do
current ratings are compareable
Now you're in the same league as the original Pass Labs stuff 😉
Just turn down central heating in winter 😉
Hannes
Hannes
or maybe find a way to couple it to the return water to the central heating system (water)
but is a really crazy thought
besides, hot air works well for heating too 😛
Neutrality, where are you getting these beasts?
From Toroidy.pl, nice prices and good service.
I can get up to 2000VA transfomers in both standard and "audio grade".
I am looking at the Toroidy.pl website and see no information on how the epoxy-filled transformer is to be mounted. Are you supposed to drill through the epoxy with a hole to the necessary size? Is that information on the site but not in english?
The Potted transformers (they call 'airtight casing') are very nice... 😀
To be honest, I have no idea. It doesnt say so anywhere on their site.
The pictures of transformers with epoxy filled centers show them to be completely filled, no holes.
The same goes for their airtight casing series.
Hmm....😕
If you're in North America then you may do better with Sumr. They seem to be very accommodating for small orders from diy guys.
SumR - Richard Sumner Technology
- F5 power amplifier
