F5 power amplifier
Hmm, should one change from fast on connector to a through-hole mounting pad instead?
Fast on is easy to work with but the most optimal solution would be to solder wires to the PSU and Amp PCB.
Regarding feedback and source resistors with higher power levels, what would a reasonable size be?
The 4 100 Ohm 3 watt feedback resistors are now 5 Watt, the same goes for the 0.47 Ohm Source resistors.
