500W PA amplifier with Limiter
hi apex audio
greetings want to ask you that can you please tell me if i am
wrong
1 pin 7 of ic TLO72 should go to base of transitor BF422 but 5 no pin is going to base
2 from 5 no pin 10K resitor should be ground
3 1 no pin of ic TLO 72 should go to base of transistor BF423 but 3 no pin is going to base
4 3 no pin should be ground via 10 K RESITOR
PLEASE TELL ME IF I AM CORRECT FOLLOWING SCHEMATIC
hopimg you can help me
thanking you
andrew lebon
hello mate,
which tlo step lay out are you using?
the corrected step lay out is in post923 and 928
apex,
in the picture you post the i.c. mounted not as the last corrected lau out,.so the step this picture is not yet tested?
my question is is it b500 need step driver? without step driver any effect?
which speaker protection is suitable for b500?
pls post the b500 correct pcb layout in pdf and speaker protection.
thank u for diy members.
B500 can run without step driver ,,step driver is just an upgrade so b500 become h class,,about protect circuit its on the thread and i use it for my b500 and h900 works great
what is the pcb size?
what about this protection bcb?
which power supply u use?
i am going to try the regulated power supply.i attached it.
which relay uusing?
i think that this circuit has softsatrt and protection circuit is for b250 i think ,,and the other is regulated psu for b500.ypu must ask APEX AUDIO for clarification
you can use that psu with softstart for b500
My unfinish PSU for B500 with Softstart i cut the protection Circuit
