Marantz CD63 & CD67 mods list
And as Martin Clark will probably point out again, you can make a tracking pre-regulator to improve a 7805 or super reg etc.
Just like this one! Although tbh, if was going to that much trouble I'd build something a little better!!
cough, like this:
It's the tracking pre-arrangement, not the minor changes that makes for good performance. Look at how it's arranged: the first 317 ensures there is *no* ripple voltage appearing across the second, in fact the second reg sees a constant voltage difference across it regardles of whayt the load does. So the second reg applies all its gain to load regulation, while the first deals only with the ripple/noise on the input. This is a subtley, but it audibly improves on just using two regs in series.
So - my suggestions are using an LED voltage drop to set c.2.8-3v across reg2, which absolutely minimises noise from the first reg (because the led at 5-10ma has a dynamic impedance of only c.20-30ohms). The added resistor(in blue) critically-damps the input to the second reg, stopping any spurious oscillation due to high loop gain / layout strays. Use 10R with C2 = 100nF down to a min. 2R7 for 1uF, or 1ohm with 10uF.
A circuit well worth playing with for the very low cost of entry.
Hi Ian,
Yes been a member for a while but not posted much. Enjoyed reading about many mods hear though.
The diagram posted is a basic tracking reg and I am actually using Avondale's pretrackers for my 5v supplies. Old Les has added a few bits to the basic layout to reduce ripple so I am not certain that Martin's tidy mod applies and that's why I asked a couple of questions.
Ah, thought you were interested in a 'from scratch' ideas. I'd leave LesW's TPRs alone, not much to be gained by chopping them about 🙂
RCruz - not necessarily. A tracking reg arrangement requires about 5-6v minimum headroom or 'dropout' voltage from input to output, whihc you may not have. A good shunt reg uses a current source to feed the load anyway, so what it upstream should be fairly irrelevant. If you want to add anything, a little RC decoupling before will help at high frequencies when the active current source starts to become less effective (but a little RC ahead of most regs is rarely a bad idea IMO!)
I guess that means no? a mystery tweak. I have no idea where they came from or if they really worked. The guy who found them was a serious DIY'er (Swiss) and swore by them. They worked on his big beautifull Sony cdp ( CDP-X707ES) but were too tight for the Marantz. End of tale I guess.
Not so early; 1985. I have looked everywhere but there is no existing reference to this.
Bonne année Frenchie! Il vas faire beau parait-il.
à propos... of nothing and everything. I turned off the current, opened up the wall sockets, tightened the wiring connections and treated everythig with Craig Gold cleaner and enhancer. Nice cheap and effective
tweak. Sounds cleaner too!
