Mic, Line, EQ... Preamps
bas amp
hi mile,
i have made thiss amp
DSC04886.jpg,
sound good,the PSU 20Vac/5A..but when volume pot fully opened ,.the final TR(tip142+tip147) very hot,and less than 1minut,tip142+tip147 got damaged.why?
This simple x-over work in range 20-100Hz, if you need this low pass instead 80-250Hz you can just use pot 2x50k instead 2x10k and sound will be same.
I have tried 50K pots but no improvement.. Even replaced the TL IC with two new ones, both purchsed from different vender... Still bass is not low as with the Lowpass circuit.
If any one else can try it.. may be all TL ICs can be faulty..
Waiting for reply from members...
Rakesh Sharma
In PA is usual to use active x-overs with amps, and there is output buffers on each channels.
yes apex if we used branded pa amp. if diy amp we dont link out, just input thats why we used buffer. say a single sub-out u cant just parallel the whole out with 8 amp. it would be better if every out going to diyamp sould have same input gain.maybe like this idea. pls help sir apex cant complete the crkt.
