Salas
Xpovia Polla !!!
Also attached is a copy of the new document that I'm working on. IT'S STILL A Beta. Any suggestion are welcomed
Pete
Wow, impressive work Pete thank you very much, please could you add to Wiki page?
Cheers
Felipe
Hi Guys,
I have a few questions for you.
I read the pete's document and I would like to know if I have the good version for my photo stage? see this link: http://www.diyaudio.com/forums/analogue-source/129126-simplistic-njfet-riaa-307.html#post2090662
second question: I would like to know what's the best after the diodes bridge between CRC ( 4700uF-resistor?-4700uF BHC) or 2*4700uF only?
thank you! Maxpou
thank you! Maxpou
I believe all versions are good. Different versions differ only by gain and JFET's IDSS.
Hi Guys,
thank you! Maxpou
Not only good but tailored to your stash and application. Its what a general guide just can't cater for. This is not a BJT phono with defined closed loop gain (global feedback). IDSS, bias, and gain are a balancing and channel matching act. Takes some individual care.
*I would avoid the resistor.
I used a 15 nF cap with a .75nF trimmer. what effect is more/less capacitance? when redo the enclosure I will snap some photos of the boards.
Evan
More is duller, less is brighter.
Correct.
May I ask why?
May I ask why?
Avoiding damping the caps further than their own ESR when not needed. Small uH RF coil between can do a good job without the resistance.
Cheers
Felipe
Hi Felipe
What is the Wiki page ?
Salas
Xpovia Polla !!!
Pete
Hi Pete
Congratulations for the splendid work
There seems to be a misprint regarding Q5 on the text and Q6 on the riaa schematic.
Can you elaborate on why did you choose 470uF for C6 on the BC550C base bias circuit ?
In your pdf text, you state you are the developer of the circuit... Why not use 220u as in the previous Salas schematics ?
I am also very interested in the Low MC pre pre that seems a good alternative to a SUT.
Did you build one of those ? Why using a 7809 and not a Salas shunt there ?
Ricardo
Hi Felipe
Hi Ricardo
Here: Salas Simplistic NJFET Riaa Schematics - diyAudio
Finally found some time to begin my second RIAA.
PS will be in an external box with 2 rcore transformers and an CL - 4700uf plus 10H. Final C 10000uF will be on the RIAA box with the V 1.2R shunts, which I completed and tested. Vin loaded is 52V and Vout 42V.
For the RIAA - it is going to the 57db for my Shelter 901 - I have already matched some 170 BL at about 8.5mA, but I also have a stash of V's. I will measure some and see how many I can match.
Also waiting some teflon capacitors from the states.
- Analogue Source
- Simplistic NJFET RIAA
