Simplistic mosFET HV Shunt Regs
Salas what do you think about using this regulator to provide cathode bias on a DC coupled amp, in order to avoid bypass caps?
The reg would provide cathode bias around 100V to the cathode of a 45 SET. I can't predict how it would handle sinking current instead of sourcing it?
I am very happy
Make your self clear senior. What all those emoticons mean? Pictures, application, what PSU before, why so happy, what is so different.😀
Yes I never suspected this kind of change using a shunt regulator for B+ (you can see I'm newbie), application: pre-amp SRPP 6922, mains Tx custom made secondaries 240V & 8.5V far better than Audionote, about reg. nothing special it's a Quang Hao SSHV pcb, about components useds:
PSU
UF4007 diodes
Nichicon UVY2W221MRD 220uF / 450V caps
1W carbon film
5W Kiwame
REG
1W carbon film
2W & 5W Kiwame
1K trimmer Bourns
100uF 50V Pana FM
1uF 450V Auricap
MOSFETS & TRANSISTORS
IRF9610
MJE350
IRF840
JFET
2SK170BL
Chassis wire: Cardas 17,5ga
Potentiometer Noble 100K or 50K I have both but surely will be definitive 50K.
The sound: incredible low deep and marked, mid sublime and high sweet and soft as the velvet never before heard so real the piano and Patricia Barber's voice, the voice of Ella Ftizgerald and Carol Kidd.
BTS = better than sex......
