Maybe someone finds this useful:
http://www.diyaudio.com/forums/solid-state/178333-2-speed-fan-controller.html
Max.
Max.
hi mile,
i have made thiss amp
View attachment 199366 ,
sound good,the PSU 20Vac/5A..but when volume pot fully opened ,.the final TR(tip142+tip147) very hot,and less than 1minut,tip142+tip147 got damaged.why?
TIP142/147 must have heatsink.
This simple x-over work in range 20-100Hz, if you need this low pass instead 80-250Hz you can just use pot 2x50k instead 2x10k and sound will be same.
I have tried 50K pots but no improvement.. Even replaced the TL IC with two new ones, both purchsed from different vender... Still bass is not low as with the Lowpass circuit.
If any one else can try it.. may be all TL ICs can be faulty..
Waiting for reply from members...
Rakesh Sharma
hi apex,
do you have pre-amp buffer that can drive several b500 amps of your? same us 1 input with 8 out.
thanks
b500 have balanced input,you can use parallel balanced input,(or through)apex just confirm if it is ok up to eight?or need new buffer for eight?
In PA is usual to use active x-overs with amps, and there is output buffers on each channels.
sir apex,hi apex,
thanks
can you please share sir a ckt of the said buffer,
please
sir apex,
please
Go to post #73.
yes apex if we used branded pa amp. if diy amp we dont link out, just input thats why we used buffer. say a single sub-out u cant just parallel the whole out with 8 amp. it would be better if every out going to diyamp sould have same input gain.maybe like this idea. pls help sir apex cant complete the crkt.
apex,
please,buffer ckt
regards
12dB/oct activ X-over with balanced input and outputs for subwoofer (LO),satelite(HI) or full-range(FR). X-over adjust 50-250Hz, and level for satelite (HI).
schematic ?
Here 100W Guitar Amp100W Guitar Amp
Guitar Amp or Bass Amp ?
Bass Guitar Amp
- Live Sound
- PA Systems
- Mic, Line, EQ... Preamps
