Pictures of your diy Pass amplifier
My B1 on the F5 top
It has a nice finished look, Stealth. Can we see pics of the display? How did you make the black front part? Is it a separate part or paint...?
Display is from the dantimax kit, front panel is assembled from more separate parts as You see below. I had a damaged 10mm aluminium panel, black part is 3mm plywood + laser print paper glued together..
regards
MY F5 tower :)
Pic 16f628 remote control, (power on/off, volume and input selector).
UPC 1237 protect.
OPA 2134 preamp, LME 49600 buffer.
2x47000 uf kendeil, 2x15000 nichicon
300w 2x18 toroid transformer.
thanks NELSON PASS.
Finally, I finished my F5 in the refurbished (new front- and backplane) Telewatt SA600 enclosure
At least nearby finished: just a LED in the frontpanel is missing.
Inside view:
Actually driving the Fostex FE83E in the bowls on top of my desk, a nearfield setup:
Below the desk, you can recognize the 15" Goodmans bass. The desk is like an open baffle. The Goodmans is driven actually by a bridged LM3886 amp.
On the right side on the desk you can see on a breadboard the miniDSP I am using as crossover (spdif out, followed by my own DAC's).
Franz
where is the ground wire on f5 pcbs?? i think you must ground your f5 pcbs....
