APEX ! I have a 650w transformer, 35v-0-35v . Can I use it for this circuit ?Schematic in JPG
If I have to change anything in this circuit ?
please guide helps !
THANKS !!!!!!
THANKS !!!!!!
You can use this transformer without any change on amp circuit.
thank you! very much !
What version of this circuit you want to build?
Harrison x1000 mentioned in #19
Hi
Great thread, good to see such a flexible design.
Back in #19 you mentioned a design based on the harrison x1000 schematic. Can you please post this schematic on the thread as I can't find a copy anywhere and I have a problem with my Harrison.
Hi
Hi
Harrison schematic is same as HH in post #18 only without protect circuit, and use 2SK1529/2SJ200 in newer series.
what/where is FB400?........... and 2SC5200/2SA1943 for FB400
I like many of the topologies adopted in this schematic.
With 5pair and 1ohm loading, what would you set the PSU voltage to?
FB400 use +/-45V DC rail voltage with 5pair and 1ohm loading.
Hello apex,
What is the Idle bias current used on the FB400 ? Recommended heat sink area necessary for 1 ohm operation ..
Hello apex,
FB400 use 200mA bias, and heatsink like for 100W class A amplifier for 1 ohm operation
http://www.diyaudio.com/forums/pass-labs/166784-pictures-your-diy-pass-amplifier.html
per device or total for all 5parallel pairs?FB400 use 200mA bias,
Would it be more helpful to builders to specify the Vre for best performance rather than Ire?
Total, but only MOSFETs are biased.
200mA for Ib
40mA per output MosFET is quite low.Total,
- DC Servo MOSFET Amplifier
