Cal's next venture
Thanks you two, those are both good ideas. I could do tinitus' idea and keep trying and I could always cut out the back of the cabinet in the coax triangle but if I do wouldn't I have to worry about wavelength cancellation (presuming a low cut off) if I do that? That is why I was asking about the holes idea. Set me straight here.
If those holes are small and very few, you got a high tuning vented box.
If you drill a lot of holes, then it become more and more like open back.
And I think it'd be not so intereting in between them🙁
I once played with a guitar driver in an open back cabinet. It sounded resonant to me🙁
The "holey" idea is going to get you an aperiodic tuning. That's probably a good thing. You can vary the amount and thickness of the stuffing over the holes to change tuning.
If you have a way to measure the impedance you can check this by looking at the impedance curve.
Scanspeak and Dynaudio used to make a Variovent for this sort of thing.
I've read somewhere that...
The holes in the back should be equal to baffle thickness ,and the total "blank"area equal to Sd ; internal volume should be lightly stuffed and something more transparent than felt should be used ,and glued near the holes. Also an additional protective grille on the outside could be posed to maintain everything firm .
Oops. I forgot the R part of PR^2. Each hole is .44 in^2. The cone is about 78 if you subtract the spider around the horn. I'm gonna wear out my speed bit. 😀
Actually I might just try a few less knowing I can add more as needed. So, to be clear on my extrapolation, a 3/4 hole on a 1 1/4" grid means there is 1/2" between them?
:Olympic:
Nice😀
All those seem to share the same hole size, so you might try the coax placed in the middle to form a WWTWW with all W on a curve and surround the coax😀
I second the WWTWW design, it will look better balanced & "probably" sound better that way as well essentially imitating a point source like Dunlavy & Montana speakers do, no?
Edited Comment: Sorry posted my response before knowing the cabinet was already built...
Thetubeguy1954 (Tom Scata)
"The man that hath no music in himself nor is not moved with concord of
sweet sounds is fit for treasons, stratagems and spoils."
- William Shakespeare
Splits are on the other side, and I saw one from here 😛
LOL
Seriously, they look good. And I'm wondering, what if overlaying another perforated board on this one (by a gap)?
Better damping (higher loss)? Or that's not necessary since the damping material inside will do the job.
