What do you mean ARTA can not measure shorted then 70msec? It can do < 1 msec. I gate measurements with ARTA down to 3 msec all the time.
btw, you have a nice software package! Too bad its not in English.
Show how you can gate 1msec.
I found it.doug20, how to do ?
Choose impulse response and you can choose custom gate.
There is no big differences in the high frequency using 2, 5 or 20 msec.
That can be caused by the reflections on the baffle. I can see improvement with the 2 msec
Try now and measure with the microphone 10cm away from the tweeter and one 10cm away of the woofer and measure with about 3msec and 20msec.
and overlay them in a window.
When they are much more flat then you have to improve the shape of the baffle.
With this way of measurement (gating) you can tweak your design to the highest level.
Post a waterfall diagram looks very colour full in arta..
clic here.
Measure also a step-response waterfall.
The spec of the 15 inch woofer aso shows a bit ragged response in the d range like your measurements show. This can mean you have to tweak the cone of your woofer.
Make cuts and place damping lines like scanspeak does. To break cone resonance.
Helmuth, sorry I didnt post yet but you have found out how to do it.
Unfortunately, outside is a huge hassle for me. No open fields close by. My room is pretty well treated though and I also have 4" thick portable panels to place behind and below the speaker to help with reflections. I can get out to 6ms so that puts the response below 800Hz. For the lower frequencies, I just measure at 1 or 2 cm from the woofer then splice back to the tweeter measurements.
Do you guys ever measure outside (gated or groundplane for eg) gating indoors below 800 hz is very difficult for accuracy , even if you have the speaker raised 1-2 M off the floor and a pretty large room...
Ok sorry , i see were you have Helmuth ......
Hi Andrea
These plots are very nice. The ribbon shout perform better IMO The woofer is much better then I aspected. So or you have to improve the baffle or tread the room.
I measured my speaker the living-room microphone 30cm from DUT with arta. With water fall.
I use a audigy 24bit sound card and measure up to 30kHz. Arta falls off above 20kHz measure flat up to 28kHz that will indicate a rise above 20kHz and that the tweeter will reach 30kHz.
Also shows it the behringer is near flat above 20kHz.
and one of the same measurement 1/24 smoothing 66msec gate.
Like original Onken I have mounted the woofer with internal flange.
This allow an acoustic centers aligned but it can create also some strange reflections.
My firts idea is to make the baffle of the onken direct left and right of the woofer angled 45degrees or so. also angled on the top of the baffle
And Place the onken output on the backside it are low frequency's with omni behaivour and you will have more profit off room gain and stretch the low end.
I had left and right, of the in and output connected to each other.Helmuth, you need to use the second channel (in loop) to compensate the sound card frequency response.
Hi Andrea
To compare the same box same soundcard same mic and preamp same postion and other software with hbx v6.
soundcard calibrated input to output flat response and fase.Other two through loudspeaker class d amp and mic-amp.
- Hi-End and Hi-Efficency loudspeakers (horn + onken)
