Congratulations, thank you for the gift.
Yes, and thank-you for organizing the GB.
Please Update the list yourselves when you type here:
1. wendell c : 3 set : $48
2. andRookie : 3 set : $48
3. df_genius : 4 set : $64
3. sandbasser : 4 set : $64
5. daanve : 2 set : $34
6. barmanekm: 1 set : $18
7. ksnider1: 2 set : $34
8. mace1337: 3 set : $48
9. CeeVee: 3 set : $48
10. merlin el mago: 2 set : $34
11. Westley : 4 set : $64
12. Groundloops: 4 set : $64
13. Ciu : 4 set : $64
14. fitzfish : 4 set : $64
15. ClaveFremen : 2 set : $34
16. Ramallo : 1 set : $18
17. number9: 2 set : $34
18. frozen wing 2 set :$34
19. bracla: 3 set : $48
20. Globulator: 1 set : $18
21. korben69 : 2 set : $34
22. analogdiy : 4 set : $64
23. rickmcinnis : 1 set: $18.00
24. guglielmope : 3 set: $48.00
25. suburra : 1 set : $18.00
26. h-wan: 3 set: $48.00
27. hawall841 2 set :$34
28. VT67: 2 set : $34
29. qusp: 2 sets : $34
30. awpagan: 2 sets : $34
31. joemana : 2 sets : $34
32. gorko1 : 2 sets : $34
33. marcus1: 3 sets: $48
34. Ryssen 3sets 48$
35. drazen : 1 set : $18.00
36. stephen1212 : 3 sets : $48
37. claudio: 1 set : $18
Total GB : 91 sets (minimum order must be 50)
Schematics Salas low shunt
Schematics Salas low shunt and PCB follow it
Hi guys, I see you are cooking me up here, I see some mods and some gross mistakes eventually picked out, still the capacitive termination and its damping are altered. This V1 class is a forgiving family, but I would highly recommend a prototype is to be made and tested in real life for spec Vo range and stability on likely load applications. Just my 2C.
V1.0 RS under V OK, only R1 current adj. 0.56R 5W instead 2.2R
V1.0 5V-35V pos. & neg.
R2 & R5 470R instead 220R
Between Source Q3 & remote sense- must have a 10R in series
Will be good if you post the pins of BC550, BC560 & 2SK170 could you get from this photo:
*0.56R R1 would run 1.2A current. In a BJT controlled CCS, the set I is one Vbe/R1. That was for #26 DHT heating. Watch it.😛
Hi Salas and merlin el mago!
I do not understand your idea, please just let me know! thank you very much!
More just your 2C.
To say in simplest way, real test on everything, before production.
Yes! I see!
Thanks Salas!
Salas have reason, better to do the exact V1.0 remote sensing that I do in my Hypnotize boards & my P2P for my Simplistic NJFET phono RIAA, so you
must left exact capacitance values like the original schematics so:
Under 5V
C9 47uF instead 220uF
Over 5V
C6 100uF instead 220uF
C8 100uF instead 110uF
V1.0 Remote Sense 5V-35V, don't forget to added the 10R between Source Q3 & Emitter Q4 bus rail remote sense-. See R5 in this photo:
Under 5V
Over 5V
35. drazen : 2 set : $34.00
Total GB : 92 sets (minimum order must be 50)
Incresed my count to 2, thanks.
Under 5V
Over 5V
V1.0 Remote Sense 5V-35V, don't forget to added the 10R between Source Q3 & Emitter Q4 bus rail remote sense- (your schematic). R5 photo schematic!!!!!!
38. TheShaman: 10 sets: $160
Total GB : 102 sets (minimum order must be 50)
Salas
Is there a benefit from using C1 - C4
Salas
Depends on chosen diode's reverse noise level. Not bad to have places for them, no big deal either. If using stably a lower Ciss & Crss CCS element the PSRR will go stronger higher in frequency and block gremlins better also.
- Group Buys
- Salas low shunt Group-design by Salas
