I think the only explanation of the BE .025 ohm resister in parallel with ceramic device is to let the high energy, high level signal bypass the ceramic device.
So, the electrons intuitively know that they are high or low energy electrons and choose the appropriate path based on this knowledge?
What happens if you attenuate the entire signal? In your hypothesis?
You mean increase the resistance of the bypass resister? I suspect it would overwhelm the ceramic device for what it needs to do. That's just a guess. This is of course backwards conceptualizing from what we know it contains. For all I know Mr. Bybee learned how to make it from trial and error and without any grand conceptualizing whatsoever.
No, I mean what happens if you (say) HALF the level of the input signal including all its components - signal, noise, extraneous hash etc. In your hypothesis, how does the artificial lowering of the entire signal affect what the QP does?
What happens if you only HALF the true signal ie noise etc are unaffected? At what point does the QP consider the signal to be noise and the noise signal?
I think it would operate on an "absolute" difference between the lowest level signal that can be separated from the grass level noise. This wouldn't change with the level of the signal. Any noise that exists above that signal level it seems to me would get through along with the signal. It would be like hiss - once its on the recording its there if its above a certain level. I'm not good at quantifying that mathematically though. If the noise arises in a circuit after the attenuator then of course your signal will go down relative to the remaining noise even if the QP stops the grass level noise. If most of the noise arises before the attenuator then the noise and signal will go down together. And then the QP will stop the margin of noise at the grass level. This is guessing. Its a dirty job but somebodys got to do it.
figured. So, the QP can't differentiate noise from signal. Anything below an absolute level is "noise" (even if its a lightly played flute section behind the brass) while anything above the absolute level is signal, even if its GSM cellphone hash.
Good mind experiment though - thanks for the thoughts and input.
btw my math sucks too. I'm in awe of people who can do differential calculus.
End of game.
End of game.
I think you might be over extending my simplified explanation. I think low level signals are pulled out of the weeds, so to speak. But that doesn't mean that sometimes the weeds are just too high and you pull some of the weeds along with the signal. It ain't quite as bad as you are implying. But like everything, there's a limit to all good things, including this.
Of the recently deleted post the only one that seemed to have content was SY saying he would return to the lab soon.
Stop posting drivel here. It makes this moderator grumpy and grumpy moderators tend to put persons in the bin.
Does any one know if the substance wrapped around the resistor is conductive, and if so what its resistance is. From the photos I get the impression it is in contact with the endcaps of the QP so if conductive would be in parallel with the resistor.
Out of respect for Cal, I haven't disassembled either of the Slipstream doodads to check this. Someone else whom I trust has disassembled the older devices and found the wrapper to measure about 5 ohms.
Cheers Sy.
From what I've read, including one revue where JB was present, the origional design of this device was to reduce the noise in power systems for subs, and especially for the sonar, as this was in the 70's I would surmise that most of the noise was at a lower frequency than today with SMPS.
So we have a conductive shield wrapped around a much lower value resistor (wire wound), if there is any effect I still would suspect it is inductive in nature and frequency dependant, how thought I am still trying to guess, unless the ceramic material has some magnetic material within it.
Depends on what day you catch him. He's also said that it doesn't affect noise and that it measures just like a resistor.
The outer wrap is more accurately described as resistive rather than conductive. And no-one seems to want to speculate about the vinyl dip coating...
Okay then, I'll go first. I suspect that it's not vinyl after all, more like some sort of sintered monolayer of Peratech Qtc pills which enhance the lateral quantum tunneling of the low noise electrons
Maybe it is used as a triboelectric retarder. Causing the electrons in that higher resistance path to fill all of the available orbits. Can't imagine why this would separate noise from signal, unless you think about signal in an information packet sense. Then random charged electrons might be more susceptible to getting lost in the resistor, as opposed to the signal packet remaining coherent and utilizing the "filled" zone controlled by the PVC triboelectric effect.
Bud, I knew I could count on you!
Well, nothing can, so that's not a surprise.
Rockwell Automation Retroincabulator
(for RodeoDave)
This short video is horribly off topic, but then again maybe not...
Yeah, I know...
(for RodeoDave)
Yeah, I know...
Of course SY, always willing to invent whole new universes to explain the phenomena that is unmeasurable and inaudible in this one. Long history of doing so in fact.
You did not overdo it, it was well stated and received..Hi John,
Huh?
Always remember that we have varying levels of experience among our members. Like any manual, some things require repetition. Personally, I didn't think I overdid that. You got the message. 🙂
If we limit bw to 20K, then just toss an 8 ohm resistor in series with the line cord.. The test is just for coupling, so many amps will work just fine pushing 8 watts up to 100 Khz or so. Heck, even a chip amp may work there.I have nothing available that will generate that unless I build it. SY doesn't either unless he wants to torture an amplifier. Nelson could help there I think.
I'd run the current into the leads further out. Then you could use the sense contacts at a known distance as you suggested. How many of us can position these contacts to a distance known to the width of a razor blade? Copper bar contacts might be a better plan though, otherwise you'll want to null any contact potential out or keep the temperature constant across the jig. See, now you're the one getting fussy about everything! 🙂
fussy is good...
As I said, put the blades 3/8 from the body of the resistor/device, and clip the current leads outboard of those.
It is not important to know the distance to "within the width of a razor blade". The blades sole purpose is to force a contact in a known, repeatable location. If one epoxied the blade flats to opposite faces of a known dimension insulating block, the contact distances would be the block dimension plus one blade thickness. Measurement via calipers would provide accuracy to 2 or 3 thousanths, which should suffice even for copper clad steel leads.
Cheers, John
If we limit bw to 20K, then just toss an 8 ohm resistor in series with the line cord. The test is just for coupling, so many amps will work just fine pushing 8 watts up to 100 Khz or so. Heck, even a chip amp may work there.
My Adcom 555 survived this just fine.
If the ceramic material has, say, 3 ohms and is paralleled with a .025 BE resistor that is a factor of 120 larger resistance of the ceramic to the resistor. The resistor is then allowing almost all the signal to go through.
We should do a lab test of a whole QP side by side with the just the inner resistor of another QP. Reduce the a signal from the signal generator until you get way, way down there. In theory, if what Mr. Bybee claims is true, the signal in the whole QP should just disappear at the output at a certain level. On just the resistor it should just get smaller and smaller until the measuring equipment cannot go any farther. He seems to be claiming, and I'm not disputing it, that it acts like a bi-directional diode operating at an infinitesimal voltage drop.
Isn't that quantization distortion?
If what Mr. Bybee claims is true, then we have a violation of the First and Second Laws of thermodynamics, which is a lot more remarkable than the sort of quantization distortion that accompanies incompetent digitization.
- General Interest
- Everything Else
- Bybee Quantum Purifier Measurement and Analysis
