Commercial Gainclone kit- building instructions
no.
Correct wiring and routing of wiring can give a silent power amp output.
I have a very small chassis (hey...it was free, so no complain) and wires run besides the transformer. Please see picture
how do you 'lift the earth'?
if the buzz has gone when the earth or the chassis ground is disconnected you could try a large 10 ohm resistor from the chassis ground to the case that will also stop the buzz but still ground the boards.
i have a good star ground but the PC i use as source is just too noisy this worked for me although i will change it for a CL-60 NTC later. do not interupt the main safety earth from the socket though that should still be connected to the chassis with nothing between it.
Hi...thanks. The boards sits basically on the anodized heatsink and so far, i have not notice the heatsink conducts electricity through the chassis.
The other problem is the LED. On one channel it turned off quite quickly (about 1-2 seconds) while the other took about 2 minutes to turn off. It slowly dims until the light dies off. Why?
I just finished mine. Surprisingly nothing exploded when I turned it on.
I do get 22mV off set on one channel and ~60mV on the other channel. I se a single transformer (The one from Poland recommended in this thread) and no pot.
Should I be worried about the difference in offsets?
nope the offset in everychip is very random only way to get 2 the same is to buy alot and test each one and pair them up as close as you can .
those numbers look fine and the offset can be + or - mV
