Okay FT-3 Interstage and Polysteyrene RIAA Caps installed.
Here is the RIAA plot and 1kHz 0dB=.3mV. FFT is growing grass again. Measurement setup isn't identical since I need to clean my bench.
THD is same as before at 0.02%
Merlin, mine does dance. If it had a pole it would be x-rated.
I will need to receck tomorrow. It is brighter sounding. Not offensive but there. I am not sure if it is just the new caps that havn't seen a charge in x number of years or a real artifact of the riaa. I am going to let it burn in a few hours tonight and try to test it tomorrow if I have time. Have to travel for the day
You had 15.7n PP testing caps, now 15n Polysterene. Which is the flat value, and a bit different tone from caps. Let it burn a bit, check on VTA see if you want to ''tweak'' the subjective HF. I use that flat alignment too. Never bright in my system, just alive in my perception. But its free to tweak by adding a bit on 15n in other systems. There are pF Micas for tuning.
P.S. Reminding my curve.
I was attributing much of what I was hearing to the Ft-3. Funny, I never believed in cap breakin until about a year ago. My Mundorf Supreme' did he same thing on my preamp. I was sad that I spent so much and had horrible sound compared to a Solen from an old project. I left them in because I was too disguntled to have the energy to take them out. It didn't take too long and they really started to live up to their reputation. I have gone back to the solens just to make sure, but switched back to the Mundorfs in short order.
These were spot on. 15.03nF, They did not fluctuate that much either from piece to piece.
6800pF 250V 1% K71-7 Polystyrene capacitors Lot of 26 - eBay (item 200495668839 end time Aug-12-10 17:21:05 PDT)
They are the same make as this value. From the same guy.
My meter showed .04nF open so I used a matched pair of 15.07
- Analogue Source
- Simplistic NJFET RIAA
