OLD THREAD DAC End by Andrea Ciuffoli
It put it in very low Ib in the BJT error amp, cut out, and burst in oscillation too, probably. Should have got hot and collapsed. You can never be too careful with parts values. Good luck from now on, and watch high voltage. Always probe with one hand in the back pocket.
Quanghao, it seems that the first BOM had some mistakes and typos... Do you have an updated and corrected BOM?
I'm sure it would save a lot of questions and problems.
Thanks!
Hi all,
I´m also wanted a updated list of the parts and the schematics of the last 2 PCB version.
Especially the power supply for I/V have changed.
You shows several typ of tubes for use:
6H6 B+ 270V
6H30 B+ 230V
6DJ6 B+ 200V
The power supply can regular 200V to 270V?
What is with the E182cc version with transformer, have news or schematics?
Klaus
I had also suggested that we start a new thread for builders of the most current DAC. When new posts are made it's always a pain trying to figure out which version of this project and boards the question is pertaining to.
Instead of this ALL IN ONE thread we should have a thread for each project ,add-on or new version of boards. The last thing we need is confusion when dealing with high voltages and high end parts.
Seems logical to me... anyone else?
I'd be happy to start the thread but if Quanghao isnt on side we go from the oven to the fire with updates and info all over the place... In my opinion this is Quanghao's responsibility.
UPDATED BOM AND SEPERATE THREAD FOR LATEST DAC QUANGHAO
Please and thank you!
If someone will post the actual voltage requirements for the groups needs, then those will become the transformers provided. Gary has just informed me that his design is not the one the rest of you are going to build.
As I said, I really am confused! However the transformers that Klaus asked about in a PM are not vastly different from what is already designed and combining low voltage 9vac windings with higher voltage windings is not difficult.
Bud
Bud
Hi Bud,
the other two PT´s I asked in the PM one is for the I/V stage of this DAC, the other is for D3a Phono Pre of Quang Hao in an other thread.
Klaus
