My new SymAsym PCB design Rev_1.3
Thanks guys for the help.
I checked with Linear Integrated System, the LSK170B/C are in stock and still being manufactured. Thanks Andrew for the tip.
They're not pin compatible with the 2SK170 but rotating Q1&Q2 back to the original orientation is no big deal.
Thanks again,
Al
I know that I am annoying but I wish to get rid of some stuff that I have. So my last question would be the amp would be based on the schematic V1.3. I am planning to add another par of output devices. Can I use 0.47R 3W on resistors R8 R9 without degrading performance of amp, or to go with original 0.2R?
Function of D1
Hi Andrew,
After some search I found that it's function was indeed meant for temperature compensation (post21 of Roender's RMI-FC100). Thanks for your help.
Although I doubt if this compensation is really needed.
Best regards,
JohnM
Another option PCB
Yes, i like to design PCB.
My PCB version of AAK's DTV rev_1.4 amp. May single layer PCB, friendly for DIYer.
Not Builded yet! may error, please double check if interest to used it.
PCB files on KICAD format.
  • symasym_DTV_v1-4.zip
