my 1st ever D-amp, WORKING!!!
Hello baldin...
please see my earlier post/s ..... the detecting "part" taken from ucd700 pdf.... it works :D combined with the MOSFET N/P switches(link to scheme posted also).... it(supply) disconnects when inputed with iether a + or - ......
my problem?? is how to -isolate- ??? the UCD oscilation from the on/off mosfets..... maybe a CLC between mosfet switch AND UcD is enough.....
did it with opto-coupler/isolator(between DC detection && mosfet switches)... im off with just using level shifters/transistor switches/inverters(only works BEST in sim, not in real world)...
still in proto though.... need a way to -MIX- , or monitor 2 ucds with just a single mosfet switch/ AMP PS...
:smash:
You might want to take a look at this ...
Simulated with 1Khz input at 2V amplitude
+/- 74 Vdc
0.5% THD
450W RMS
650 Khz switching freq
Of course these are simulated results, but taking in consideration that LT spice is a reliable tool you could reach those results using a 2 layer pcb design.
Best Regards,
Savu Silviu
