It's a little off-topic now, but with all that filtering here, should one really care what type of trafo will go in front of the DCB1 ? Poorly made ones excluded, of course.
As I said, mainly a luxury. But if you are touchy you can pick them up. Looks like the ones with best primary to secondary isolation and electrostatic screening cut more EMI mains garbage that goes around in the loops.
I think I'll test an R-core I found on ebay for this one. 15-0-15 @ 250mA + 0-9 @250mA. That should work well and I can use the second winding for a DAC I intend to integrate with the buffer. I'll need to heatsink it well, but since current draw is low, I can afford to drop some volts.
How high can I run my voltages, what do you think?
Yes, you can run it with a trafo above 12vac. The output voltage will be a value fixed by the leds.I think I'll test an R-core I found on ebay for this one. 15-0-15 @ 250mA + 0-9 @250mA. That should work well and I can use the second winding for a DAC I intend to integrate with the buffer. I'll need to heatsink it well, but since current draw is low, I can afford to drop some volts.
The only downside is that the mosfets will run a bit hotter, but nothing to worry too much.
regards,
regi
tea-bag,
I sent payment via paypal on the 6th, but still mark as unpaid on the sheet. Did you get my payment ok?
I did get it. Thanks for checking. Out will try to send out a paid up list soon.
Paid List
dvb-projekt
mach1
kannan_s
skaos
Thror
rsotirov
pchw
alazira
Cobra2
fcaton
vegges
Korben69
jameshillj
arrow
cooi
sandbasser
Atilla
hawall841
wct
number9
ccliu
thor61"
rmsds
HiljaisuudenMeri
wendell c
roboazar
pstech
1MOR
gervenja
CeeVee
specialidiot
Russellc
ndwalker1
brickj
BDL
macronaut
dvb-projekt
mach1
kannan_s
skaos
Thror
rsotirov
pchw
alazira
Cobra2
fcaton
vegges
Korben69
jameshillj
arrow
cooi
sandbasser
Atilla
hawall841
wct
number9
ccliu
thor61"
rmsds
HiljaisuudenMeri
wendell c
roboazar
pstech
1MOR
gervenja
CeeVee
specialidiot
Russellc
ndwalker1
brickj
BDL
macronaut
Unpaid list.
Still pretty big. No shame in it until Friday
kudret
derwhalfisch
saavas
ciagon
wushuliu
samkhanski
damohpi
gjfim
igwt
toufu
qusp
Ryssen
sdman
musical
robazar
Kakerlak
Grimberg
Ferrari
prooptiki
Ed LaFontaine
grufti
h-wan
Michi124
DaveM
RichLund
ichiban
bjohng
hallcon83
samoloko
Nick77
ernesternest
HDGR
jhead
kudret
derwhalfisch
saavas
ciagon
wushuliu
samkhanski
damohpi
gjfim
igwt
toufu
qusp
Ryssen
sdman
musical
robazar
Kakerlak
Grimberg
Ferrari
prooptiki
Ed LaFontaine
grufti
h-wan
Michi124
DaveM
RichLund
ichiban
bjohng
hallcon83
samoloko
Nick77
ernesternest
HDGR
jhead
Can I still add the PRP resistors to my pcb buy?
Sure, just paypal $4 x sets to me. Make sure spreadsheet has correct amount.
- Group Buys
- GB for DC coupled B1 buffer with shunt PSUs
