Hi Tea Bag,
Just paid for 4 sets of resistors. Hope you can package them with the 2 blue boards.
Thanks,
Roumen
Got it.
Got it.
Hi Tea Bag
just sent payment for 1 Blue Hypno board and 1 set of PRP via paypal,
Tea Bag has started testing the Blue Edition board. So far every part goes in well and it works without noises. Its very early, no proper testing yet, but its progress.
very fancy
Is It necessary so much filter capacitance on smoothing caps
how this setup compare with your previous build - common diodes and resistors for B1
can you describe difference
what Is preferred type transformer to power DCB1 - EI, toroidal, R-core
Hi Tea Bag
did I miss something? What is the PRB?
Thanks in advance,
Russellc
Thanks in advance,
Russellc
PRP. The resistors.
very fancy
When running +/- 200-400mA, more capacitance is better. This board is hot rod friendly.
R-Core. Discrete primary to secondary, no field, expensive, not that easy to source. Don't know the quality of those seen on ebay.
Its better than previous since it incorporates hot rod & film caps mod. Not that you can't mod the previous, but its a bit narrow for those mods.
The more sensitive a circuit is I can perceive the R-Core as softer in tone and more dynamic. Like it has cleaner AC. And I mean in comparable situations where there was no interference with other types. In line level like here it manifests less and its rather a luxury, but when you ask, yes R-Core is best IMHO. The French source one is proven. Made in India.
I use to wonder the sameIt's a little off-topic now, but with all that filtering here, should one really care what type of trafo will go in front of the DCB1 ? Poorly made ones excluded, of course.
Regi
- Group Buys
- GB for DC coupled B1 buffer with shunt PSUs
