500W PA amplifier with Limiter
B500
Hi,Apex.
I had discovered why my B500 little buzz on speakers when there is no music. My computer is generating that sound. When I disconnect cinc, it stops. 🙂
Can amplifier work with 2SB817/2SD1047, BD249/BD250 transistors without changing anything, with lower voltage? I have some supplies of those transistors. 😀
Hi,Apex.
See post #40, and in thread http://www.diyaudio.com/forums/solid-state/164630-50w-mosfet-amplifier-irf540-irf9540-3.html you can also see post #23. Can you post some pictures? What speakers you use, and how its sound with B500 compareing with another amps?
B500 is stronger then most amplifiers I had build before.
Great sound on hifi speakers, used Pioneer and EI Nis for Hi-fi test.
And Eminence Kappa 18" and Delta 12" LF for PA test.
Will post pictures in a few days.
I had look you posts, this amplifier is just like B500 but with 2SB817/2SD1047 transistors and 2K2/5W resistors. Are there any change in pcb?
You can use B500 pcb for B250,
And pcb of Apex 120 with BDE83/84.
One of my technics of making PCB: 🙂
1.print PCB on paper
2.Use iron to transfer print(lines) on PCB
3.put pcb with paper in cold water
Rack is waiting for second channel and toroid transformer. Will post pictures soon,when finish whole amplifier.
My PA200 is visually very similar with yours B500, but weaker. 😱
