SemiSouth Donuts
who cares for amps :clown:
Mighty ZM is exploring these dayz ....... timeless pleasures
look - no left , no right .... just deep down ....... right through the mono
When a pair of speakers are used for mono, it creates the most realistic imaging I've ever heard. The artist just pops into thin air between the speakers--hard to believe that we can't get a good, modern, mono recording.
To create stereo effects takes excellent engineering, which I'm not certain is abundant. Of course, it could be that I'm being lazy--I have to build two amplifiers to have stereo. 😉
for Buzz & Stajo ....... and Stajo & Buzz
so , I'm dumb
while , few years ago , I was contemplating about these amps I knew that servo is clever thing to have for iteration with CCS loading on top , I didn't realize that for split load choke one doesn't need servo , at least not for having same DC potential on two outputs :rofl:
(so - it isn't new that I'm dumb , it also isn't new that I know that ..... and what's new is that I realized what's written above :devily: )
reason is so obvious that I don't need to explain it
however - potential mismatch between two output mosfets (Jfets , whatever) can lead to unequal current through two halves ...... and you know that chokes are not humble but humable , when put in that position :clown:
in practice , one need to use matched mosfets ( preferably at 2A , where Iq is set ) and any further tweak regarding L-R Iq is easily achieved with small trimpot in source of input Jfet , on more current hungry side
note number 13 - you both know that , irrelevant which part is used here ( IRFP , SJEP , SJDP , cascoded LU - all of them easily adopted with just FB net change ) , max power is in range of , say , 15W/8R
that figure coming from Iq of 2+2A , and load of 8R , which is , in fact , more like 4+4 - at least concerning each half of amp
so , I'm expecting that this thingie is gonna work , maybe without or just little polishing
now , I need to implement some of things simmed here , to Magura's Donuts - to slightly change lower CCS arrangement , just because he was either lazy to implement some NTC correction circ in , or it was absolutely impossible , taking in account that difference in temp between full temp and Dodo of his amps is some 5(five) C :rofl:
pics are result od LTSpice sim , so usual disclaimer - that's sim ........ and - even more important - sim by Mighty ZM :devilr:
edit - both pics are for 1W output
R085 or R065 are most likely candidates. I found out from Mike that R065 is indeed enhancement mode, but with lower Vt than R100 of about .4V.
Question. How do you go about choosing transformer for this amp. I think you suggested 500VA and 110 secondaries. You know me, I dont know squat about chokes and this is first choke loaded amp.
Project down the road, as I am imbedded in another at the moment🙂, but i would like to order toroid now as part of GB.
please - search in Magura's posts what's L of his (air) chokes
then look for biggest toroid you have at home , measure it's primary inductance ( mains disconnected , please :rofl: ) and you'll know what to expect
I mean 500VA core is minimum , going up can't hurt
I'll make sim with SJEP for which I have models ; later - all you'll need is to fiddle a little with bias pot
CCS mosfet - I recommend IRFP150 - big honker
Whats wrong with testing with connected. BUZZZZZZZ
Hey Choky,
Sorry for off topic.
Are you still using tube amps? I'm thinking about dipping my toes... got a good thread for me to follow?
off topic :rofl:
yo my woodie man
not really lately , at least not in vivo ; had fingers in making some hybrid ones ( toob susy gain stage by ZM , circlotron out by Juma , previous to that some toob SE shebang gain stage for Ge SE follower (Bata Bane)) , some resurrection of my old WOT preamp ....... ande LTSpicing my UGS called Brynhildr :rofl: , which is also hybrid but , luckily , with only toob as active element
having too much toobz and parts , few complete monoblocks for restoration , but not enough time ; however - I'm leaving all that for my 70-ies , when I hope will have more time :clown:
sweet but fast , for your sweet razor horns - for upper you can choose something based on EL/PL36 in SE triode , for lower maybe the same , only in PP
best to ask residents young ones in toob room - SY and bunch ....... Shoog's balanced thingies are also interesting
Que?
you see that I'm connected ....
