Intro a circuit of study..
A small Experiment
Hi Guys !
I tried small Experiment that with PSU without constant voltage regurater.(for amp_circuit and Power circuit , using same PSU)
Result
1.Thereis no hum noize from speaker.
2.At no inputsignal:
the PSU Voltage is +28V/-28V
and 0.2Vpp liple.
3.Max power ( 16W 8hom register load) ,
the PSU Voltages is down to +27V/-27V and
0.5Vpp liple with 0.1Vpp signal wave according
to the input signal is .
The max voltage to the polyester film capacitor is remarkably decreasing at the high frequency.
( ex:there were a case it decreases up to about 10V even by
630V(DC) in 20KHz in.
Therefore, it was felt that it was good there is a constant voltage regurater the case of use cap of 50V.( in this circuit C16,C17)
New Constant Voltage Regu
Hi Guys!
I have tried a new constant voltage regurater.
And overcurrent protector is good working.
I feel good...
Regards.
Some refine
Hi !
I have some refine of the new Amp Power up max 60W .
main circuit
http://www2.plala.or.jp/puthoff/gazou_mk2/amp_WD_MS010_Mk2.GIF
(I have overwrite the FIG)
Q3,Q4 (C2362K/A1016K) to C2705Y/A1145Y
The register of Power MOS FET is lessed.
R13,R18 for DC servo is 10kohm/470kohm to 1Kohm/47kohm,
so Good for the OPamp that input is bi poler Tr about noise.
(this type LPF canseling music signal is able to decrease the register number)
Regard!
Only a idea of amp
Hi All!
I have a only chip idea of AMP circuit diagram with OP Amp.
( may be already many have known ...)
The one that a part of circuit of my recent amplifier was cut out,
and It modified views.
I think that the second one is easy to make high Voltage OP amp...
(It is current F/B type )
New explain the recent amp working
http://www2.plala.or.jp/puthoff/material/EXP_MK2_V2.pdf
Thank you
Thank you The Guy,your comment and advices.
I think that the sound by increasing outputVOL useing supply rail of OPamp is nallow range sound....so ,I 'll thinking and study more more now and in the future,to similar.
P.S
I know the reason why your reply was soon deletion ,but I understand your geniality,
Very very thank you.
Some Simulation study
Hi I have Some Simulation study.
first about this AMP circuit
"http://www2.plala.or.jp/puthoff"
It is a result of comparing the control deflection with LT1364 and MK2 type circuit
(Parts are different in a simulation and a real machine. Because I do not have the data of the part. )
<Condition>
Feedback circuit :1k ohm / 47k ohm (GAIN 47 times)
The load resistance : 1k ohm
Input signal :1KHz sin wave - 200mV (DC offset cancellation in the input element.)
Output : 9.4V
<Results>
(1) deviation
LT1364 : 3.2 mV
MK2 : 24nV
(2) the inversion of the open-1KHz
LT1364: times 5875 (75.4dB)
MK2: double 783333333 (177.9dB)
<Data>
The study chart
Second study
Hi second study,it's about CVR
The small signal Tr 2SC1815/A1015, output Tr 2SC4973/A1837 are the alternative .
The output voltage is approximately 34V
Output current
f = 1KHz and 100KHz
DC: 115mA to AC: ± 40mA output current superimposed state.
Output impedance
1KHz: 3.75mΩ
100KHz: 6.25mΩ
thrd study
Hi third study .it's about precharge to power Relay on ,to maincharge and CVR begin to start and SP protect Relay ON.
1.Power relay circuit is delayed by CR circuit.
While this time the precharge signal is on output.
2. The power relay is ON when 17V.
Then, it gradually turns OFF pre-charge signal.
3. When the precharge signal become OFF, the constant voltage regulator begin to start.
4. When the output voltage of constant voltage regulator become high enough, Speaker protect Relay is connected.
