sorry,apex,
distribution amp
this is the way how i understand eesiboy
in like manner,this is how many commercial mixer does, it is the sub outs
where we can assign more amp in the same or different application
sub
mid hi
monitor
this is a good question
hope to hear you soon
regards
eesbiboy
too late to edit
Replace two 1nF condensators in input stage with 100pF,apex,
this ML3 is working
except the treble
good mid
good bass
maybe i.c.D fail
i will try to change TLO74
i will update you after
regards
You mean tree or four way active x-over?apex,
distribution amp
sub
mid hi
monitor
regards
sir,...sorry,
eesbiboy
too late to edit
what do you mean by that???...
apex,
distribution amp
sub
mid hi
monitor
regards
suppose a 3-way is already there
for low mid & hi
how can we use multiple amp for low/sub
Active four way x-over have separate outputs for sub, mid-bass, midle and horn amplifiers, like Mackie 'fussion' system,suppose a 3-way is already there
for low mid & hi
apex,
sorry for so many questions
i checked crown i.t4000/8000 manual
and found that it has provided another xlr connectors the signal at these connector is paralleled with the input signal for feeding the signal to another amplifiers
can i use post #73 and add another XLR connector for feeding the signal to another amps?
regards
regards
Yes with balanced input/buffer (post #73) you can use any amp you want in paralel connectin,apex,
regards
apex,Yes with balanced input/buffer (post #73) you can use any amp you want in paralel connectin,
is post 73 a balanced input/buffer?
can you post a balanced input/buffer
Yes in post #73 is balanced input/buffer, volume control have not influence on input impedance with this circuit on amp input.apex,
Single pre out to multiple ampa
Hi, some or even most of the pro amps this day have link out male XLR balanced out to daizy chain multiple amplifiers.
Apex had also posted a balanced input pre amp with link out XLR port, that would I think fit your requirement.
Thanks, good luck:
>Joel
Philippines
Thanks, good luck:
>Joel
Philippines
apex,Replace two 1nF condensators in input stage with 100pF,
1nf already change to 100pf
treble still not working
please help
You must post pictures with both pcb sides.apex,
please help
If you use mono jack (-, non inverting) will be shorted to gnd, and you get unbalanced input automatly when inserted jack. Can you post better picture of coper side pcb,apex,
see my input jack tip & ring to input +/-
when guitar jack inserted +/- is shorted
i use guitar when testing
- Live Sound
- PA Systems
- Mic, Line, EQ... Preamps
