Pcb layout for H900V2 is different. Do you have this pcb layout?
On this pcb two pins of 0R22 5W must be moved 2,5mm left, in post #560 is correct pcb.
Thanks.
YesHi..Apex...For H900 can I used BYV26E instead BAV21? Because I have it..
Pozdrav
Terima kasih banyak (Indonesian)..Thanks alot...
Pozdrav
In Serbia we like to say:Terima kasih banyak (Indonesian)..Thanks alot...
Pozdrav
"Govori Srpski da ceo Svet moze da te razume"
(speak Serbian whole World will understand you)
Indonesian in your case,
I can't Serbia...I just click Serbia forum with Google Crome..and I find some word like Pozdrav, Hvala puno, hvala ti, slazem se.. Also my english is very bad...
Your english is better than myI can't Serbia...I just click Serbia forum with Google Crome..and I find some word like Pozdrav, Hvala puno, hvala ti, slazem se.. Also my english is very bad...
Yes NJWs are better, but I have no expirience with them.NJW3281G (NPN)
NJW1302G (PNP)
Are those better than 2sc5200/2sa1943 ? I have found them at the same price (2 .5Usd per pair) and i don't know which to use ..
Do you mean H-class step driver with TL072?The voltage control circuit can be used to switch the rails of an Mosfet amplifier like AV400 (FROM +-75 to 2* +-35V ) ?
With Ir2117 or sometring like that
sorry , now i found this http://www.diyaudio.com/forums/atta...w-h-class-pa-amp-limiter-apex-step-driver.jpg
hi apexaudio
greetings building another channel h 900 using in output
mj15024 mj 15025 4 pairs
1 matching 2n5401 and 2n5551 what gain reading hfe is good same what
reading should mje340 mje 350 have
cannot find mjl21193 mjl21194 metal ones flatpack ones are available but
very costly any other output transistors better than ths to recomend time
to pack amplifier great sound
thanking you
andrew lebon
thanking you
andrew lebon
2N5401 and 2N5551 matching to have same hfe, and MJE340/MJE350 also.hi apexaudio
thanking you
andrew lebon
MJ21195/MJ21196 is also good for outputs,
Hi Apex, thanks for your generosity of sharing most of your designs and knowledge to us DIYers.
A great pleasure to see your posted projects and un-ending support to all confused minds.
I'm fascinated with this H-class 900 amp of yours which I am about to build and plan to drive a dual 18" subwoofers, (4 ohms: 2 parallel 8 ohms).
I have on hand most of the components both passive and active.
Now, I have 2 options on what output transistors to use which I wanna ask for a professional advice from you.
I have here 20pcs of each of the ff output Qs:
MJ15024 / MJ15024
MJ21193 / MJ21194
All are TO-3 package.
Which of those pair will you suggest for this project.
If its not much to ask, is it also okay if I'll make 8 pairs of output transistor for each channel? I mean it's like 8 NPNs and 8 pcs PNPs?
If I do so, what safety values of voltage rails should I use for this one?
Is the 80-60-0-60-80 secondary voltages will just be fine?
Thanks so much in advance and sorry for lots of questions here.
>Joel
(Philippines)
MJ15024 / MJ15024
MJ21193 / MJ21194
>Joel
(Philippines)
You can use any of this pairs, and no need more the 6 pairs, H-class made for that. 80-40-0-40-80 secondary voltages will be just fine.Hi Apex, thanks for your generosity of sharing most of your designs and knowledge to us DIYers.
MJ15024 / MJ15024
MJ21193 / MJ21194
>Joel
(Philippines)
- 900W H-class PA Amp with Limiter
