Which models? Do you have schematics? Only this topology (quasi AB or H with nmos) is interesting.EAW and ECLER uses NVMOS in their amplifiers
DPA-T SERIES - Ecler - Sound experience
I dont have schematic of ECLER, but i have built Class-H/G with N-channel MOSFET and IGBTs also.
Yes, please,Little off topic,
Speaking of Ecler DPA series, does someone want to share with us those schematics? Btw, I have Ecler PAM2600/1400/1000/600/300 series, service manuals if you're interested.
Thank you, ECLER use quasi nmos output stage for PA on right way, like ARCAM for Hi-Fi with bootstraping positive rail... not like many diy designs, there is much to learn if anybody want to use this topology.Little off topic,
Can I get this schematics too ?
qsaelectronic@yahoo.com
thanks
Little off topic,
Do you know Class H NMOS amps too ?
I think all Ecler are Class AB
No, only resistor output optocoupler will work in limiter.@ apexaudio
Does Input Limiter in your class H amp work with 4n35 or 4n32 LED LDR device too ?
does work IC HCNR201 or HCNR200 work as optocoupler limiter in your circuit ?
any substitute IC for HCNR201 ?...another supplier / brand
I not found resistor out optocoupler in case like ICs.does work IC HCNR201 or HCNR200 work as optocoupler limiter in your circuit ?
See post #119, only comutation diode is different.Apexaudio, can set h900 v2 components? Thanks
I agree, this is something new for me, and I like to see this optofet in some comercial amplifier in limiter circuit.H11F1 optocoupler from Fairchild works best, as it contains a floating JFET with ON resistance=200 ohm
I need this kind post 109This can help.
Pcb layout for H900V2 is different. Do you have this pcb layout?Yes.Thanks.
- 900W H-class PA Amp with Limiter
